HD audio decoding problem with my LG-BD300 and Sony HT-IS100... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-12-2009, 11:14 PM - Thread Starter
madvlam's Avatar
dear all,
this problem is so annoying it is driving me crazy , here is my setup in brief:
BDP: LG BD300 (HDMI to Amp)
Amp: HT-IS100 (HDMI to TV)
first of all let me stated that i am truly aware the Sony IS100 is NOT capable to decode HD audio (TrueHD, DTS-HD MA) but it can handle LPCM 5.1/7.1 at 96kHz or less (according to manual), so i reckon i have two options when enjoying Blu-Ray movies:
1. do decoding at my BDP and send LPCM signal to my Amp
2. send bitstream to the Amp directly and let it "downgrade" to DD for TrueHD and DTS for DTS-HD MA.
ok, the "downgrade" option described above works fine but i wanna try something better (i.e. option 1). so i check through the manual (see the manual extract in the attachments) and on my LG BD300, set digital audio out to "[PCM Multi-Ch]". however under this setup, the IS100 always shows the input as PCM 2.0 - i m absolutely clueless and local LG support seems unable to help me - anyone has any idea?
* there is a note on the LG manual which said "When [HDMI] option is set to [PCM Multi-CH], the audio may output as PCM Stereo if the PCM Multi-Ch information is not detected from HDMI device with EDID", i dunno how EDID comes into the picture and how i should resolve this... the IS100 have two sound field settings "Auto Format Direct Std." and "Auto Format Direct Multi" - i really dunno... (again see attachment)
appreciated for any kind of help,
thx.
vincent.
madvlam is offline
Reply Home Theater In A Box
