Help with Home Theater for Basment Den - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-30-2009, 11:12 AM - Thread Starter
Rhat's Avatar
Just completed finishing out a small area in my basement for a den/theater area, but now I need some suggestions for an audio system. I am going to pick-up either a Samsung 46" LN46A550 or Sony 46" KLN-46V4100 as the TV.
I was told to go with 2.1 due to the size of the room, but I am not convinced...can someone offer advice on 2.1, 3.1, 5.1 for the set-up as well as any systems they would suggest?
Here's a pic of the layout...
Rhat is offline
post #2 of 5 Old 07-31-2009, 06:29 AM
m_vanmeter's Avatar
at least consider 3.1 as your minimum setup. Some a/v receivers can do a decent job of creating a "phanton center", but there is so much audio information on the movie center channel soundtrack it really does require its own speaker. A really nice front 3 speaker bundle from Jamo (units are selling out fast - this is a very popular sale) http://www.wwstereo.com/#/ecommerce/...103__0_0_0_-1/
for surrounds (in less than optimal positions if you want 5.1) consider dipole speakers mounted on the side walls. The dipole design will difuse the sound a bit and help with the out of position mounting.
you will need an a/v receiver, like the Yamaha V565, Onkyo SR606 or 607, Pioneer 919, or Denon 790.
For subwoofers, you have many good choices - http://www.hsuresearch.com/products/stf-1.html
http://www.edesignaudio.com/product_...roducts_id=407
http://www.thespeakercompany.com/T25...r-P103C17.aspx
good luck
m_vanmeter is offline
post #3 of 5 Old 07-31-2009, 06:36 AM
localnet's Avatar
Do you have a budget? If so, how much are you looking to spend? Out of curiosity, did you run speaker cable for rear surrounds when you finished the room?
Mike
localnet is offline
post #4 of 5 Old 07-31-2009, 06:46 AM - Thread Starter
Rhat's Avatar
Thanks for the info m_vanmeter.
Mike, I'd like to stay under $600-$700 if possible. Yes, I did run speaker wire for the rears.
Rhat is offline
post #5 of 5 Old 07-31-2009, 07:14 AM
kschles's Avatar
I decided on the Onkyo TX-SR507 receiver:
http://www.amazon.com/Onkyo-TX-SR507...9048380&sr=8-1
and a set of Energy Take Classic speakers:
http://www.amazon.com/Energy-Take-Cl...9048599&sr=1-1
and Energy subwoofer:
http://www.amazon.com/Energy-ESW-8HG..._bxgy_e_text_b
Amazon was offering a $50.00 rebate on the Onkyo receiver (don't know if they still are). I've got Amazon prime (free shipping) so the total cost was $717. Very, very happy with the results. I'm currenly using a 3.1 configuration (may add back speakers at a later date). The Onkyo receiver has several settings to simulate surround sound with only two or three speakers.
I tried the CT500 Sony soundbar. While I would have been happy if the Sony had worked, I went through two bad units. The Onkyo/Energy combination does sound much nicer. The downside? More wires, even using only three speakers and a subwoofer. It's definitely worth it. Look at the CNET review of the Energy speakers:
http://reviews.cnet.com/surround-spe...?tag=mncol;lst
kschles is offline
Reply Home Theater In A Box
