New! Yamaha YSP-4100 - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 169 Old 01-13-2011, 05:35 PM
don.juan's Avatar
Just received my 5100 today...1070 euros + 5 euros to ship it from Austria to Portugal...!
don.juan is offline
post #152 of 169 Old 01-17-2011, 02:50 AM
don.juan's Avatar
Albeit having read several topics on the issue, I'm still not sure either to use bitstream ou PCM Liner on the PS3. It is connected to the YSP via HDMI and the YSP - 5100 is also connected via HDMI to my LCD. It is one of the latest PS3 - SLIM 320GB with the last firmware. Any suggestions? (and why?)
don.juan is offline
post #153 of 169 Old 01-28-2011, 07:03 PM
Sybaris's Avatar
Has anyone ever gotten the message, "Can't Change!" on their YSP display when they try to change the volume?
I have a satellite receiver and bluray player hooked up to HDMI 3&4 on the YSP. The HDMI out goes into my TV. If my TV is not on I can adjust the volume on the YSP. TV on and I get, Can't Change! and there is no sound out at all.
I've had it all connected like this for 7 months and it was fine until today. There is another person in the house who might have pushed a wrong button but they swear they didn't.
Panasonic TC-P58V10 HDTV
Yamaha YSP-5100 Soundbar
Hsu VTF-2 Mk III Sub
Sybaris is offline
post #154 of 169 Old 01-28-2011, 09:42 PM
Sybaris's Avatar
Fixed it.
I went into the YSP setup menu and switched HDMI Control off then on.
Sybaris is offline
post #155 of 169 Old 02-08-2011, 06:45 PM
mechanicallion's Avatar
while watching video from any source (stb, blu-ray, apple tv) there is an occasional loss of picture on the tv. any of the 4100/5100 owners having the same issue? i can't figure it out for the life of me as it's very random and you never know when it's going to happen.
mechanicallion is offline
post #156 of 169 Old 02-19-2011, 10:25 PM
patatorz's Avatar
Hello, i use a 5100 since 6 months and I did not see this issue.
Best regards
patatorz is offline
post #157 of 169 Old 02-20-2011, 08:58 AM
don.juan's Avatar
Anyone with the discrete codes for the YSP-5100?
don.juan is offline
post #158 of 169 Old 02-20-2011, 09:09 AM
patatorz's Avatar
What are The discrete codes ?
patatorz is offline
post #159 of 169 Old 03-15-2011, 02:08 PM
tmm0f5's Avatar
Hey All,
Thanks in advance for any help. I have an ASRock Vision 3D (with BluRay) that was connected to a Sony 60" LED and worked perfectly with the included PowerDVD package for playing BluRays. Now I have hooked up my 5100 hooked up (all via HDMI) and now PowerDVD tells me that my display cannot support playing BluRays.
Any thoughts on what I have to do? Streamed movies work just fine.
Tim
tmm0f5 is offline
post #160 of 169 Old 08-31-2011, 09:51 AM
patatorz's Avatar
Hello, does The 4100 has a chip to upscale video ? If yes, Is it possible to passthrough this chip (because The BD player can have a better chip for upscaling) ?
patatorz is offline
post #161 of 169 Old 09-04-2011, 03:27 PM
sprelligosi's Avatar
Yamaha ysp-4100.
Has anybody been able to update the firmware with an ipod or computer.
I dont´t own a DVD or CD player. I have a PS3 and i cant update it via the HDMI input, it needs to be coax or optical.
sprelligosi is offline
post #162 of 169 Old 04-29-2012, 05:42 PM
askjeffro's Avatar
Its been a couple years since this has come out. Any word of a YSP-4200 (successor) coming this summer?
askjeffro is offline
post #163 of 169 Old 04-30-2012, 07:30 AM
Chrys7's Avatar
5100 was the last version I heard of have not really looked into an upgrade as my 4100 is still kicking strong.
Chrys7 is offline
post #164 of 169 Old 04-30-2012, 08:53 AM
askjeffro's Avatar
I emailed Yamaha and asked, will post the answer assuming I get one.
post #165 of 169 Old 05-01-2012, 07:52 PM
askjeffro's Avatar
Here is the response I got for anyone else searching:
Jeff,
Thank you for you rinquiry regarding Yamaha product. At this point there hasn't been any mention of a replacement unit. The YSP-4100 has been out for a couple years and historically we replace models every year or two. But with that said there still hasn't been any announcements yet.
Best Regards,
The Yamaha Customer Support Team
Take it for what you will... Prompt professional response, quite nice.
post #166 of 169 Old 05-18-2012, 07:27 PM
YeuEmMaiMai's Avatar
Most likely issue with HDMI handsake being interrupted. I have issues with my PS3 and Xbox and my LG3230 if I try to use 1080p 60. 1080p /24 and below play just fine though.
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #167 of 169 Old 12-17-2012, 01:42 AM
patatorz's Avatar
Hello, would somebody know if it is possible to unable the 1080p upscale for the SD sources ?
Best regards
patatorz is offline
post #168 of 169 Old 01-14-2013, 12:10 PM
caper_1's Avatar
Liked: 26
had anyone had problems with the wireless subwoofer FM receiver shutting off ?? i am asking for a friend
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #169 of 169 Old 03-16-2013, 04:08 PM
rogerg10's Avatar
Hi
Ive got exactly the same problem with connecting a yamaha sub to the ysp-4100, just cant get it to work. Ive gone through the menus and added the sub manually, however when i run the auto setup it just states "Subwoofer not available"
Driving me nuts as its only 1 wire!!
rogerg10 is offline
Reply Home Theater In A Box
