NEW Release! Onkyo HT-S5300...Any Good? - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 785 Old 07-20-2011, 05:15 PM
Accuracy158's Avatar
Originally Posted by crazyrob425 View Post
Now i wish I waited alittle before I jumped the gun on my purchase
That is an extremely good value for money. While the speakers may not be the best its a great starting point
I'm still crying over the fact that I bought an Onkyo HTiB a few weeks before they released a model with HDMI and true HD.
Accuracy158 is offline
post #722 of 785 Old 07-28-2011, 09:39 AM
hotshotmedic's Avatar
just received an email from onkyo informing me that my subwoofer that is part of my 5300 system may be defective, plugged in my serial number and YES it does in fact have a defect. ya know what? F this company, I'm tired of sending things in to get repaired and losing enjoyment out of what should have been a solid system. The goddamn regional repair center that they use are CLUELESS and wanted to charge me for a warranty repair on the amp until I contacted Onkyo and had them clear it up with them. Wasted my time, my money for long distance phone calls and my patience, last purchase from Onkyo EVER!
heres the stupid link http://www.onkyo.ca/001_modelreturn_entertype.cfm
hotshotmedic is offline
post #723 of 785 Old 07-28-2011, 09:59 AM
sollord's Avatar
Huh I got the same email but my sub isn't under recall though that might be a database issue
sollord is offline
post #724 of 785 Old 07-28-2011, 01:11 PM
bluedoggy1's Avatar
can this system use video from one source and audio from another ie iPod port or aux in bcuz it also switches video signal. TIA
bluedoggy1 is offline
post #725 of 785 Old 07-28-2011, 08:20 PM
Morac's Avatar
According to the site, my subwoofer has the "open" problem and they're sending me a box to ship it to them to get "fixed". As far as I'm aware my sub works fine, so I'm not sure what they are fixing.
Morac is offline
post #726 of 785 Old 07-30-2011, 01:14 AM
mcjefferson's Avatar
Hi guys, can i pair a front speaker rated 8ohms at 110watts to this receiver? i am so desperate to replace the front speaker as i listen a lot to music. if yes, can i played music at high volumes?
mcjefferson is offline
post #727 of 785 Old 08-02-2011, 12:54 PM
gspfunk's Avatar
It can from an audio only source like CD or Tuner. I'm not sure about the Port, though.... Aux will not likely work either as it can be a video input.
Same for me. They've obviously had enough issues they're trying to get ahead of it..... Hopefully the new sub is a little beefier...
I don't see why it would be a problem... The 130w that Onkyo rates the R580 at is running 1 ch @ 6ohms. Multiple channels at 8ohms should be well below that....80-100w I would guess.
gspfunk is offline
post #728 of 785 Old 08-05-2011, 06:08 AM
FeS RoY's Avatar
Sub-Woofer Speaker Driver Replacement Program
07/19/11 - Onkyo USA has determined that there is a high probability that the voice coil of certain subwoofers in the Home Theater and Speaker systems listed below may open; consequently, the subwoofer will stop functioning.
For our valued customers, Onkyo USA has a speaker driver replacement program for the affected subwoofers. It is important that you check the model and serial number of your subwoofer.
Please click on the following link for more infomation on whether your subwoofer is eligible.
http://www.onkyousa.com/001_modelreturn_entertype.cfm
If you are eligible for this program, an Independent Onkyo Regional Service Center will send you material and instructions to return your subwoofer.
You can also contact Onkyo USA Customer Support during normal customer support hours (M-F 9am-8pm and Sat-Sun 10am-4pm ET) to see if your subwoofer falls under this speaker driver replacement program. Call toll free 1-855-460-1618 or local (201)785-2654.
FeS RoY is offline
post #729 of 785 Old 08-05-2011, 01:38 PM
Morac's Avatar
I got my box from Onkyo. The repair center is in Illinois. I'm not sure it pays to ship something to get repaired when it works fine though.
Morac is offline
post #730 of 785 Old 08-07-2011, 07:58 PM
Thank you for this, i will replace my previous toplist in searching speakers and decided to go to monitor audio.bx2 for front and bx-centre for center maybe my current front will be my surround if budget limits me.
post #731 of 785 Old 08-15-2011, 02:35 PM
oldirtdog's Avatar
a friend of mine sent his in even though it worked fine and when he got it back there was a dent and scratch on one of the corners. they must have damaged it at the distribution center while working on it...
good thing they sent him 2 subwoofers back though, the second one didn't have a scratch on it
oldirtdog is offline
post #732 of 785 Old 08-15-2011, 05:15 PM
FeS RoY's Avatar
sent mine in also... should receive it back in a day or 2... will post outcome
FeS RoY is offline
post #733 of 785 Old 08-18-2011, 01:03 AM
prashp1's Avatar
I sent mine in last Thursday and they got it this past Monday. Then yesterday I received the subwoofer back. They got it on Monday and shipped it back same day. What work did they do?
I hooked it up and tested it. It worked fine. I wonder what kind of work did they do or didn't do any work, since the shipping was on the same day as they received it.
prashp1 is offline
post #734 of 785 Old 08-18-2011, 03:23 AM
FeS RoY's Avatar
got mines the day before yesterday.. it seems like all they did was add CA Glue smh
FeS RoY is offline
post #735 of 785 Old 08-18-2011, 05:50 AM
Spacebob11's Avatar
I got mine back yesterday. It was about a week turnaround including shipping. It doesn't look like they did anything. They even reused the duct tape I used to seal up the box and plasic bag I put the subwoofer in.
I sent my receiver in for the firmware upgrade so I can't test it. It never had problems to begin with. It's been 2 weeks since I sent my receiver in with no status update from Onkyo (even after a few emails). I'm getting pretty tired of using my TV speakers...
Spacebob11 is offline
post #736 of 785 Old 08-18-2011, 01:00 PM
dc1225's Avatar
was there a recall on the receiver as well that I missed?
dc1225 is offline
post #737 of 785 Old 08-18-2011, 01:39 PM
Morac's Avatar
Other than the original wrong speaker MPCM bug, I'm not aware of any.
There's another issue I have occasionally where the receiver misidentifies Dolby digital audio as Dolby II. This is with PCM sources. The workaround for that is to switch to another input and back.
If the turnaround time for the sub is only a week, I guess I can send it in. I've had the shipping box lying around for a few weeks.
Morac is offline
post #738 of 785 Old 08-22-2011, 12:15 PM
Spacebob11's Avatar
So it looks like Onkyo lost my receiver when I sent it in for the firmware update. The tracking number they had on record for sending it to the E. Syracuse was faulty so there is no tracking. I called the service center and they don't have anything on record for service for it. I was on the phone with FedEx for over an hour and they can't find any record being shipped to the service center from my location.
Has anyone else had this much trouble with sending something in for repair? Any advice?
post #739 of 785 Old 08-23-2011, 02:39 AM
Guys i just replace my front speaker and it seem's they're sound much better now compared to the included one.By the way,can i add a pre amp to our receiver?if so how can this be done? there is no pre out in the back.
post #740 of 785 Old 11-17-2011, 10:14 AM
broadwayblue's Avatar
Quoted: 35 Post(s)
Originally Posted by snorton007 View Post
Yes they did add the latest decoders...It also looks like it no longer has the hdmi pass through like the older models had...
Was this verified? Is it true that this receiver does not offer HDMI pass through? Perhaps I'm confusing pass through with processing. I want to be able to simply send the HDMI signal through the receiver without subjecting it to any processing. That is still possible, right?
broadwayblue is offline
post #741 of 785 Old 11-21-2011, 06:33 PM
Morac's Avatar
I put off sending back my subwoofer so long (nearly 4 months) that the shipping label that came with the box expired. I finally got around to calling Onkyo and they sent me another label so I'm going to ship it out tomorrow (to beat the holiday shipping rush). From what I've been told, they are simply replacing the speaker drivers in the subwoofer. I really hope they still have drivers left considering I took so long.
Anyway, for those who went through the process, do they send out any kind of notification or tracking number when they ship it back or does it just "appear" on your doorstep?
Morac is offline
post #742 of 785 Old 11-30-2011, 05:20 PM
Joeforsale's Avatar
I actually admired the fact that onkyo notified me about the sub. I had tvs before that had known issues and I was the one that had to contact the company. For my first real surround setup I think the receiver is great but will replace the speakers when I get the cash. Any tweaks and adjustments for a great sound people can recommend?
Joeforsale is offline
post #743 of 785 Old 11-30-2011, 05:36 PM
Morac's Avatar
I shipped last Tuesday. Apparently there were closed Friday since even though it "out for delivery" by Thursday, it didn't get delivered until Monday. I have no idea what state it's in now. It could be on it's way back or sitting in a pile of boxes in a warehouse.
Morac is offline
post #744 of 785 Old 12-01-2011, 10:57 AM
homerofwar's Avatar
Hopefully that gets sorted.
I wasn't even aware of this, I went to the site and sure enough my sub was on the list. There sending me a box, hopefully it will turn out fine.
homerofwar is offline
post #745 of 785 Old 12-01-2011, 06:11 PM
Morac's Avatar
I'm beginning to get a bit worried. They received it on Monday (they signed for it). Based on posts here and from what Onkyo told me on the phone, the repair is very simple and should be done the same day (they're just replacing the driver) assuming they have the part.
As such I would have expected it back today, but I haven't gotten any shipping notification. I called Onkyo the other day, but they told me I have to call the repair center (which is a different company). I meant to do that today, but forgot.
I haven't had the subwoofer since November 22nd so it's coming up on almost 2 weeks. This is why I don't like sending things back when they aren't broken. I don't understand why they can't send someone out to my house to repair it. That's what Sony did with the recall against my TV.
Morac is offline
post #746 of 785 Old 12-01-2011, 07:12 PM
Joeforsale's Avatar
Take a breath everything will be ok. I'm sure if it gets "lost" in the mail Onkyo will set you up with a new one. In all seriousness mine took right around two weeks.
post #747 of 785 Old 12-02-2011, 11:06 AM
Morac's Avatar
I ended up calling the repair place and after some initial confusion (since they said they don't do end user repairs on Onkyo products), they emailed me that is has been fixed and that they will be sending it back today and gave me a tracking number.
I was hoping to get it back by this weekend, but at least I know it's on its way.
Morac is offline
post #748 of 785 Old 12-02-2011, 07:07 PM
ben7337's Avatar
Quoted: 24 Post(s)
Does anyone know why this receiver has a standby mode light it can never use? The manual says it will never fully power down when you press on/standby, and no matter what I do, when it turns off, it just leave the hdmi passthrough light on. The standby light never comes on like on my old S3100.
Furthermore it still feels hot even when off because of this. Is this thing just sitting pretending to be off, draining electricity like a mini space heater? Because that's what the manual seems to say.
ben7337 is offline
post #749 of 785 Old 12-02-2011, 07:22 PM
Morac's Avatar
For me the Standby light comes on when I turn off the receiver if I disable HDMI Control in the HDMI setup.
Morac is offline
post #750 of 785 Old 12-02-2011, 07:25 PM
Joeforsale's Avatar
Good to hear. I was going to say earlier that I was pretty sure they sent me tracking info for mine, but I wasn't 100%.
Reply Home Theater In A Box
Speaker Systems , Onkyo
