Onkyo HT-S9100THX volume problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-03-2010, 07:12 PM - Thread Starter
m51
m51's Avatar
i just got the Onkyo HT-S9100THX in today. i followed the instructions here on this website for setting up for the ps3 and i get dts-hd and 7.1 but i have another problem that i dont understand
the maximum i can turn the volume up to is +5 db. the instructions say that its supposed to go up to +18 db.
according to the troubleshooting guide in the manual, all my settings are correct regarding this problem.
i ran the calibration thing with the microphone twice.
any help i would appreciate alot
m51 is offline
post #2 of 9 Old 06-03-2010, 09:18 PM
MandM's Avatar
Quoted: 77 Post(s)
Liked: 39
Re-read pg 87 of your manual under Volume Setup. Post back if that doesnt fix your issue.
MandM is offline
post #3 of 9 Old 06-03-2010, 10:03 PM - Thread Starter
m51
m51's Avatar
yes that was the first page i read. nothing there helps.
m51 is offline
post #4 of 9 Old 06-03-2010, 10:16 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi m51, what is the speaker trim levels set to after calibration?
IMO the best way is to purchase a SPL meter and manually configured the speakers.
JChin is offline
post #5 of 9 Old 06-03-2010, 10:21 PM - Thread Starter
m51
m51's Avatar
im sorry i dont know what speaker trim levels are.
where can i find this?
edit - sorry if im supposed to be on a less technical forum. i just came here because i know that people here know what they are talking about.
also everything sounds great; blu rays and video games sound fantastic. im just bothered that the volume doesnt go up as high as they manual says that it should
m51 is offline
post #6 of 9 Old 06-09-2010, 07:51 AM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
wow, no one can help this guy? M51, try posting on the official 9100 thread.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #7 of 9 Old 06-14-2010, 10:23 PM - Thread Starter
m51
m51's Avatar
well i fixed this problem but just posted another question in a new thread
where is the official 9100 thread?
m51 is offline
post #8 of 9 Old 06-17-2010, 08:11 AM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
http://www.avsforum.com/avs-vb/showthread.php?t=1057095
Set up:
post #9 of 9 Old 11-03-2012, 09:54 PM
jimmykoss's Avatar
How were you able to fix the maximum +5 issue? I have the same issue and I have run the auto calibration feature six times with the same result. I am not sure exactly what happened because my sound used to be almost twice as loud. I turn it up all of the way to +5 and it is not nearly as loud as it used to be. The maximum sound level was previously +18. Can anyone help?
jimmykoss is offline
Reply Home Theater In A Box
