Onkyo HT-S7300 Bass issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-28-2010, 03:24 PM - Thread Starter
Nataku4ca's Avatar
So, I finally decided to take the plunge and bought the 7300 last weekend. After setting everything up I noticed one tiny problem.
Whenever I start the receiver the light on the bass stays red and I have to manually go into audio setup and click on the setting where you change the db(can't remember what the option was) and move the cursor to bass for it to turn blue.
Is this normal? or did I miss something...?
(didn't see another thread similar to this so I decided to start one)
Nataku4ca is offline
post #2 of 11 Old 09-28-2010, 09:45 PM
MandM's Avatar
Quoted: 77 Post(s)
Liked: 39
Without going into setup first, play an audio source. Does the light turn blue? If so this is normal.
MandM is offline
post #3 of 11 Old 09-29-2010, 05:26 AM
oligeo's Avatar
Indeed,
If HT-S7300 reacts as my HT-S9100, the Sub goes idlle when not required by the system (low volume, no bass requiring the sub in a given sequence,...). Sometimes, in a movie, after a sequence with loads of bass and effects (action sequence for instance), the sub may go iddle because the next sequence is quieter (dialogs for instance).
Hope that helps
oligeo is offline
post #4 of 11 Old 09-29-2010, 01:43 PM
samsurd2's Avatar
It's one of the compromises that can come with buying an HTIB. Many subwoofers that are not part of an HTIB have an "AUTO ON" capability like that included in the OP's subwoofer. However they also include the ability to set the subwoofer to ON so that the listener does not suffer from the consequences of bass levels that change as a function of what the input source is and, therefore, may or may not activate the subwoofer. If HTIB manufacturers want to save cost by not including the ON option along with the AUTO ON option, just have the subwoofer ON all of the time and be done with it. IIRC, that's the way most older HTIBs were configured. JMO
samsurd2 is offline
post #5 of 11 Old 10-01-2010, 11:04 AM
MooseLover's Avatar
I also have the 7300. On the back of the sub adjust the volume to about half. It should kick on the next time you have a movie or something with some bass. When i set up audussey it set my bass to 0 so that should get you to around reference once you get it set, the way you want. (I.E. speaker placement and such)
We need a 7300 thread so we can discuss little things like this. What kind of speaker mounts did you get for the surrounds?
MooseLover is offline
post #6 of 11 Old 10-02-2010, 02:05 PM
flyfl1pguy99's Avatar
yes i agree with you. We need a 7300 thread for all our needs.
I myself just purchased this HTiB. I am still about 75 complete with my installation. I finally received my speaker wires for my surround sound.
So maybe this weekend ill be able to complete my hook up.
I am still a bit confuse about the optical and hdmi.
So a few of my friends have told me that without optical cables, i wouldnt be able to hear the full capabilities of the system. So i went ahead and bought a couple of optical cables. My setup is like this.
TV hdmi and optical to receiver
Sat. box hdmi to receiver
ps3 hdmi and optical to receiver
IS this a good set up? What would be the best set up for my equipments?
flyfl1pguy99 is offline
post #7 of 11 Old 10-13-2010, 11:38 PM
omgitsoop's Avatar
Whoever told you that is retarded, optical audio can't carry dolby true hd, dts ma-hd, and can only carry 2 channels of pcm, while hdmi can carry all of that plus 7 channels of pcm, plus you only need the one cable.
omgitsoop is offline
post #8 of 11 Old 10-15-2010, 04:12 PM - Thread Starter
Nataku4ca's Avatar
hi everyone,
Thanks for responding, I got caught up between work and my gf and couldn't come reply for the past week lol (gf had a week of vacation off school)
oligeo is right, and I didn't figure that out until very recently
I've got most of my stuff connected now, now I'm just trying to figure out a way to get the receiver output to show when I watch TV lol, not being able to see volume control on screen was alittle annoying... I think a PVR will probably fix the last of my problems
best purchase I've made in a long time
thanks again for replying to this thread
post #9 of 11 Old 10-26-2010, 10:41 PM
charizo's Avatar
anymore user reviews of this HTIB?? worth pulling the trigger on?
TIA
charizo is offline
post #10 of 11 Old 11-08-2010, 09:28 AM
ezdlr's Avatar
Just got all hooked up, can`t figure out to set up so i can play all speakers, can only get fl c fr speakers to operate, open to suggestions. by the the way this the fourth srs i have owned and by far the best with only 3 speakers working,, will even be better when set correctly thanks
ezdlr is offline
post #11 of 11 Old 11-08-2010, 01:40 PM
samsurd2's Avatar
^RTFM starting with page, especially "Advanced Setup" starting on page 38.
samsurd2 is offline
Reply Home Theater In A Box
