Bose CineMate GS Series II vs Bose CineMate Series II - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Which 2.1 systems is better ?
Sony - BRAVIA 3.1-Ch. Home Theater Soundbar Speaker System with Subwoofer Model: HTCT350 0 0%
Bose® - CineMate GS Series II Digital Home Theater Speaker System 2 66.67%
Bose® - CineMateSeries II Digital Home Theater Speaker System 1 33.33%
Bose CineMate Series I Digital Home Theater Speaker System 0 0%
Voters: 3. You may not vote on this poll
post #1 of 22 Old 12-17-2010, 08:56 PM - Thread Starter
jokerm3's Avatar
What is the difference between the three in terms of sound quality?
Bose® - CineMate® Series II Digital Home Theater Speaker System
Bose® - CineMate® GS Series II Digital Home Theater Speaker System
And how does the Bose compare to the Sony - BRAVIA 3.1-Ch. Home Theater Soundbar Speaker System with Subwoofer Model: HTCT350 or sony CT359
jokerm3 is offline
post #2 of 22 Old 12-17-2010, 09:25 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Sh*t, Sh*tty, Sh*tier
No highs, no lows it must be Bose
Start with a Denon DHT-591ba
crazyrob425 is offline
post #3 of 22 Old 12-17-2010, 10:10 PM
MGSBigBoss's Avatar
Go with the BOSE Cinemate GS Series II, it is a upgrade from the standard cinemate. you wont be disappointed and the BOSE cinemate i think is more vibrant and has good ranges. Now you won't get TOO much of a difference from the 3 however. Alot of them are revisions in terms of port and connections. You will get similar sound from all of them. BOSE is high quality and ignore the haters.
MGSBigBoss is offline
post #4 of 22 Old 12-17-2010, 10:14 PM
MGSBigBoss's Avatar
Actually I'd go with the BOSE Cinemate Series 2, I dont feel the GS and the standard are much different. So if the price range is drastically different go with the cheaper one but if they are about the same go with the GS. Also you will get 5x better sound from the BOSE than from the SONY Soundbar or most soundbars for that matter. Having the 2 speakers will really give you more distinct and discrete 2 channel audio. The soundbar will almost sound like its coming directly out of the tv speakers cept a bit more clarity.
Go with the BOSE.
post #5 of 22 Old 12-17-2010, 10:32 PM - Thread Starter
jokerm3's Avatar
Go with the BOSE.
Thanks for the feedback, I actually just came back from best buy earlier and felt the cinemate series 2 sounded a little more rich, maybe it is the different sample sounds the bose stand was playing. Only thing the GS got me on right now is the size of it love the jem stone look its. The price differnce is 200. The regular one is 599 and the GS is for 799? But he cinemate series I is for like 440, havent heard that yet.
jokerm3 is offline
post #6 of 22 Old 12-17-2010, 11:29 PM
Quoted: 443 Post(s)
Liked: 337
Before you buy Bose please at least read this article:
http://www.intellexual.net/bose.html
I am not a Bose hater but someone who can appreciate good audio quality and Bose are rip offs. For the price of the Bose you can get a real quality setup. Sorry I am the messager of the bad news....
post #7 of 22 Old 12-18-2010, 08:13 AM - Thread Starter
jokerm3's Avatar
Thanks for your candiate feedback however, for space I have in my living room. What other 2.1 speaker system do you recommend ?
jokerm3 is offline
post #8 of 22 Old 12-18-2010, 08:21 AM
Quoted: 443 Post(s)
Liked: 337
Whats the size of you room? And ultimate budget? Do you mind a normal size receiver?
post #9 of 22 Old 12-18-2010, 08:27 AM - Thread Starter
jokerm3's Avatar
12 ft distance from tv. wall 4.6' I want to budget about 600. don't mind a receiver but the main thing it might be hard to pull wiring for 5.1 as I have floor to ceiling windows behind my couch.
jokerm3 is offline
post #10 of 22 Old 12-18-2010, 08:53 AM
Quoted: 443 Post(s)
Liked: 337
Could you give me the total dimensions of the room length x width x height?
Do you need 3d capable receiver?
post #11 of 22 Old 12-20-2010, 03:39 AM
davyo's Avatar
I have owned and had in my house ALL the systems you listed.
My recomendation,,, the Yamaha YSP-2200,, can be had on Amazon for well under the MSRP.
Cheers
Davyo
davyo is offline
post #12 of 22 Old 12-21-2010, 02:55 PM
zoey67's Avatar
Quoted: 179 Post(s)
Liked: 97
Davyo...is the 2200 much better than 4000 or 1100?
zoey67 is offline
post #13 of 22 Old 12-22-2010, 09:54 PM - Thread Starter
jokerm3's Avatar
I have a 3d tv what is the point of a having a 3d receiver?
jokerm3 is offline
post #14 of 22 Old 12-22-2010, 11:24 PM
thebard's Avatar
Quoted: 88 Post(s)
Liked: 51
A receiver that is not 3d-capable will not properly pass the 3d video signal. You will need an hdmi 1.4 receiver, or will need to have the hdmi cable bypass the receiver & go directly to the display.
Projectors: Where there's a wall, there's a way.
http://www.avsforum.com/forum/110-di...een-build.html
thebard is offline
post #15 of 22 Old 12-23-2010, 09:47 AM - Thread Starter
jokerm3's Avatar
So i currently have the sony kdlnx810 and a sony ps3 can i just connect my ps3 to the tv and then from my tv link it to the receiver?
jokerm3 is offline
post #16 of 22 Old 12-23-2010, 10:04 AM - Thread Starter
jokerm3's Avatar
Do u have the yamaha how do u like it and where did u pick it up at ?
jokerm3 is offline
post #17 of 22 Old 12-23-2010, 01:27 PM
Quoted: 443 Post(s)
Liked: 337
You will most likely lose your surround sound effect if you do that as most tv's don't output 5.1/7.1 surround audio only 2.0
But the yamaha ysp-2200 has 4 hdmi inputs and the surround bar can decode the latest Audio codecs
post #18 of 22 Old 01-23-2011, 09:24 AM - Thread Starter
jokerm3's Avatar
where can i go to check out the ysp2200
jokerm3 is offline
post #19 of 22 Old 01-23-2011, 09:24 AM - Thread Starter
jokerm3's Avatar
btw im in nyc
jokerm3 is offline
post #20 of 22 Old 01-01-2014, 11:37 AM
Rjst145's Avatar
The yamaha ysp-2200 has no low-end guts at all. Look at the Paradigm model for performance.
Rjst145 is offline
post #21 of 22 Old 01-01-2014, 02:07 PM
Otto Pylot's Avatar
Quoted: 1596 Post(s)
Liked: 1001
^^^^ if the poster from 2011 is still around waiting for a response, he may just do that wink.gif
Otto Pylot is online now
post #22 of 22 Old 01-30-2015, 01:20 PM
Liked: 0
I bought a Bose Cinemate GS series II like 6 months ago. The sound quality is awesome, but the fact that I can't adjust treble is bothersome. Usually movies sound like the dialogues come in at a low volume but then the explosions are amplified. There is no automatic adjustment between the highs and lows. Is there any hack to connect the system to a receiver? I've checked other forums and Bose says the system has a built in equalizer i.e. they don't want people screwing around with any settings than what they have chosen, which is not optimal for me. Please help!!
smanzoor3605 is offline
Reply Home Theater In A Box
