Advice Needed! Sony BDV-E570 5.1 making it into 7.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-11-2011, 02:34 AM - Thread Starter
Pmarszal's Avatar
Dear AVSers....
I just purchased a Sony BDV-E570 5.1 Home Theater System. I was looking to buy the 2 extra speakers to make it into a 7.1 system... Now i have no clue about audio stuff and looked on Sony site for the extra speakers but I have no clue where to even start....
Does anyone know how to purchase the 2 extra speakers.... Can they just be any brand bookshelf speakers?
Which ones do you recommend?
I really dont know anything so please try to describe as best as possible!
Pmarszal is offline
post #2 of 4 Old 01-11-2011, 10:33 AM
Tulpa's Avatar
Liked: 61
I'm going to go out on a limb here and say that it would be a real neat magic trick to turn a 5.1 system into 7.1 if it only has speaker outs for 5.1. As far as I can tell, that system can't do 7.1, unless I'm missing something.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 4 Old 01-15-2011, 03:46 PM
MMWright31's Avatar
According to the manual you can....you just have to use the optional wireless surround kit...
MMWright31 is offline
post #4 of 4 Old 01-15-2011, 04:06 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Originally Posted by Pmarszal View Post
Dear AVSers....
Most likely know you need to use Sony s-air speakers so readmthe manual and go from there
crazyrob425 is offline
Reply Home Theater In A Box
