Official LG LHB326/336/536/976 Owner's Thread - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 231 Old 11-22-2011, 05:20 PM
Deke2011's Avatar
Originally Posted by Connestee View Post
Casey, yes our 536 remembers what source we were using the last time before we turned it off. Occasionally when switching channels a lot, like when following two or more football games, the unit will not output and we have to push the home button on the remote and choose input and then select HDMI1, which is the input our satellite receiver is plugged into. It doesn't happen much, though.
There is a quicker way then pressing the Home button, just go straight to the input by pushing the input button.
I have yet to update my 536, as I currently do not have it hooked up to the internet, soon though just waiting on my new wall unit.
I would like to see a fix for; I have a LG TV as well and I use the simplink function, it works great providing I don't leave a disk in the player.
How it works is; whatever I'm watching on the TV and I want to send the audio to the 536, I just press simplink button and choose HT instead of TV Speakers, it then turns on my 536 if it's off and changes the input to ARC if it's not currently on it. (I use the HDMI1 on my TV as it has ARC capability)
Works good, but it's not 5.1, it's only stereo, wish they (LG) would fix that too.
Deke
Deke2011 is offline
post #152 of 231 Old 11-23-2011, 05:07 AM
Connestee's Avatar
Deke
Same here on the TV, we have the 55LW5600 and it will not pass through 5.1 audio. It's not a problem since we run HDMI from our satellite receiver direct to the 536, but for those with older equipment or those who have to run audio through the TV it blows that many LG TV's will not pass through 5.1 audio. They do need to fix that.
Connestee is offline
post #153 of 231 Old 11-25-2011, 10:52 AM
Connestee's Avatar
Out of no where our 536 is not outputting the NFL channel received via DirecTV (channel 212) in 5.1 audio. Its stereo of some kind, and our other sound system-TV setup that is connected to the same source still outputs the channel in 5.1. I have no idea what happened and it's the only channel I have found at this point that is doing this. Go figure??????????
post #154 of 231 Old 11-25-2011, 07:36 PM
Deke2011's Avatar
Yes, funny thing I noticed that as well, when watching Directv through the 536 it's not 5.1, it says PCM2/0.0, I'm guessing that is just stereo. Is it all the channels or not?
I get 5.1 via a BD or mkv files via a harddrive on usb port.
Deke
Deke2011 is offline
post #155 of 231 Old 11-26-2011, 05:10 AM
Connestee's Avatar
Deke
NFL channel is the only channel so far. I scanned a lot of other channels to see if I could find another that was doing the same and came up empty.
OK, I have to edit this post. Just after I posted the NFL channel was the only channel that I was having a problem with I turned on our 536 which is connected to a LG 55LW5600 TV and found the same problem not only with the NFL channel, but with several channels in the 500-560 range on DirecTV. These are the HBO, Startz, TMC, Cinemax movie channels for those who are interested. I'm going to call LG and see what is going on here.
Edit again after talking to LG support, they tried, but were unable to help. I may try switching out DirecTV receivers to see if that makes any difference.
post #156 of 231 Old 12-03-2011, 05:43 AM
Connestee's Avatar
When I first start the disk in our 536 there is nothing coming from the center speaker. All I have to do to correct it is to push the sound effects button on the remote and bump it to a different setting. I usually have it on natural plus, but it doesn't matter what it is set to, it happens every time.
post #157 of 231 Old 12-04-2011, 01:49 AM
DeAd MiKe 187's Avatar
Happens to me OFTEN with Blu-rays.
DeAd MiKe 187 is offline
post #158 of 231 Old 12-05-2011, 12:30 PM
phillyeagles2008's Avatar
Hello and Good day fellow LG owners I just wanted to share a little good news atleast I think its good news... I don't know if any of you are familiar with Samsungs new touch screen remote for the 8000 and 9000 series, but they charge a hefty amount for it, but LG offers 2 remote apps that I think are just genius... One is for Blu-ray players that I tested and it worked on my LHB976 and could quite possibly work on the 536 and 336 and one app for their HDTV's which I've tested on my 55LW5600 and it works flawlessly... There's only 2 things you need a Android Smartphone and a Wireless connection, aside from powering on the HTIB or TV you would never need the remotes that came with the HTIB or TV not even the wii like remote which gets emulated by a mouse like tracking on your touchscreen Android...
phillyeagles2008 is offline
post #159 of 231 Old 12-06-2011, 02:10 PM
Kravmanaut's Avatar
I have the 535, and am thinking about upgrading. Almost all of my gripes have been addressed (double click remote, audio quality, youtube quality settings, hulu+, amazon vod), but I wanted to ask about one last thing:
Sometimes its easier for me to watch Netflix from my Xbox. However, my Xbox is plugged into the 535, not the TV directly, and due to some digital protection of some kind, it says it can't make a secure link.
One solution could be to plug the Xbox into the TV (LG Infinia 47 something or other) and then run audio to the 535. I would like to avoid this because it would require switching inputs around every time I play, which is added hassle to an already input switching heavy system).
Does anyone know if the 536 addresses this problem? Or is there something can change with my current setup to fix it?
Kravmanaut is offline
post #160 of 231 Old 12-07-2011, 05:37 AM
Connestee's Avatar
I don't have an Xbox, but I believe your problem may be HDCP related after doing a google search. Here is some interesting info:
http://formatwarcentral.com/2008/10/...lix-streaming/
post #161 of 231 Old 12-07-2011, 09:00 PM
Deke2011's Avatar
What's a good speaker stand for the rear speakers of the LHB536?
Deke
Deke2011 is offline
post #162 of 231 Old 12-09-2011, 08:44 PM
osogovo's Avatar
osogovo is offline
post #163 of 231 Old 12-20-2011, 10:14 AM
Lrncephil80's Avatar
Hello all,
Has anyone in this post bought the LG LHB326 version? I just bought it at Walmart for $228. I bought it b/c of the price and b/c it mentions ipod connection. I planned to buy my ipod soon but I don't see where the ipod would connect. Is via the usb port or that headphone jack?
Lrncephil80 is offline
post #164 of 231 Old 12-22-2011, 08:12 PM
Originally Posted by Lrncephil80 View Post
Hello all,
The attachable iPod dock should be in the box.
post #165 of 231 Old 12-28-2011, 10:24 AM
are you saying this from personal experience or assumption? There wasn't an ipod dock in my box
post #166 of 231 Old 12-28-2011, 03:51 PM
I have the 536 and it came with an iPod dock. I made the assumption that yours would come with one also if it said something about an iPod connection.
post #167 of 231 Old 12-28-2011, 09:48 PM
choster's Avatar
hi, i have my l have the LG hb536 hooked to my xbox 360 via optical but it dosent give me a 5.1 sound, what could it be?
choster is offline
post #168 of 231 Old 12-29-2011, 01:14 AM
pokekevin's Avatar
Liked: 102
Did you set the audio correctly in the xbox settings?
pokekevin is offline
post #169 of 231 Old 12-31-2011, 05:17 AM
Connestee's Avatar
Did a manual check for firmware update on 12/30 and found one, but I don't know what it did.
post #170 of 231 Old 12-31-2011, 12:08 PM
It's for the new Netflix update. Netflix is now much less buggy (can't find any bugs now, in fact), loads faster, and supports 5.1 surround sound on all titles that have it, as well as English subtitles on almost all videos. What a nice surprise. I wasn't expecting this model to get the new Netflix update. Very cool!
post #171 of 231 Old 01-01-2012, 04:44 AM
Connestee's Avatar
Streaming Netflix has always been the most troublesome feature of our LHB536 in regard to the player freezing up, especially if we try to adjust the volume shortly after starting a show. We stream Amazon a lot, too, and it doesn't happen nearly as often.
This is good news and thanks for explaining what the update did.
post #172 of 231 Old 01-01-2012, 03:25 PM
No problem! I was always having tons of Netflix problems, such as videos taking forever to load, not being able to resume a video after fast-forwarding, the player rebooting after trying to load a video, etc. I'm very happy to say that I haven't come across anything like that since updating (and I've watched about 6-7 different videos since and have done various things to try to cause the program to bug out).
post #173 of 231 Old 01-01-2012, 05:37 PM
Avonbeauty's Avatar
I'm extremely frustrated. Had the 536 about three weeks now, it refuses to update, even via USB. Maybe I'm doing something wrong here or in the wrong order. Could someone please give me a step by step on how to get this thing updated once and for all???
Another issue, it seems to keep dropping the wifi connection every time I turn around and I have to re-enter everything all over again. What's the deal with that?
Edit: Ok, after changing the order in which I was trying to get the update to take via USB, it finally took...thank goodness!
But, does anyone have any insight into what's going on with the wifi connection dropping.
Avonbeauty is offline
post #174 of 231 Old 01-01-2012, 08:06 PM
That's definitely an unusual issue. Doing the following usually clears up weird issues:
Go into Settings, and Initialize. Then shut down the player. Unplug it, plug it back in, and turn it on. Put your WiFi information back in. Reboot and let me know if it stays.
post #175 of 231 Old 01-02-2012, 01:47 PM
Rush-Fan's Avatar
Hello all,
I am considering buying the LHB336 and want to know how the setup is going to work before I buy it.
I have an LG 50" plasma and Dish network receiver. We also have a wii and an xbox360. Currently, we have no home theater and just use the tv speakers for everything.
What is the simplest way to set up the LHB336 with this setup and have surround 5.1 for all the systems?
Obviously, I have an HDMI cable going from the Dish receiver to the TV right now. If I set up the LHB336 going into HDMI2 on my tv, will I get 5.1 audio while watching TV on the Dish receiver, ie. will the audio go back to the LHB336 via the HDMI cable? Or do I need to do something else?
I'd really prefer to not have to switch the input on both the TV AND the 336 everytime I want to switch between xbox/Dish/blueray etc. I want the surround speakers to be the default speakers no matter what device I am using, instead of the tv speakers.
I hope my questions make sense. Thanks in advance for helping out a newbie!
Rush-Fan is offline
post #176 of 231 Old 01-03-2012, 11:28 AM
The 336 only has one HDMI input, I believe. The 536 (which I have) has two HDMI inputs. With that, you can have the Dish connect to HDMI1 on your 536, and the Xbox 360 (or the Wii - not sure if Wii uses HDMI) connect to HDMI2, and have the Wii (or the Xbox 360) connect to the 536 using Toslink Optical Audio.
All of your devices will use the 536's speakers.
post #177 of 231 Old 01-03-2012, 12:02 PM
rbird's Avatar
There's an iPhone/iPad app as well. Haven't used it much, but it exists.
I have a lot of trouble updating too. Been a problem ever since I got my 336 (nearly a year now). I was completely unsuccessful in getting it to update via USB. Can't imagine it's the wifi causing the issue, since I have no problems with Netflix or other apps. Any other suggestions?
I don't believe the Wii has a digital audio output of any kind. At least I never noticed one. That's ok though, since the 536 has an analog input as well.
You are correct that the 336 only has one HDMI input.
rbird is offline
post #178 of 231 Old 01-04-2012, 09:16 AM
choster's Avatar
sorry my mistake, i find out that the game that i was playing (dance central 2) not always give sound to the rear speakers, only it certain moments. thanks =)
choster is offline
post #179 of 231 Old 01-04-2012, 03:51 PM
Avonbeauty's Avatar
The new Netflix update isnt cooperating and I can't use the app at all. There's not an available download on the LG site so that I can even try doing it via USB. The update that I downloaded the other day via usb, which I thought was the Netflix update, turned out to be the new driver update. Oddly it seemed to fix the Netflix problem for a couple of days. Now I'm back to not being able to use Netflix. Very frustrating.
post #180 of 231 Old 01-04-2012, 04:51 PM
Did you do this?:
Reply Home Theater In A Box
Lg Brand , Lg , Blu Ray Players
