Samsung HTIB with 7 year old TV? Need some help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-16-2011, 07:32 PM - Thread Starter
luelf21's Avatar
I have a friend that just purchased a new samsung 5.1 HTIB in which the amp/receiver and bluray player are all in one.
http://www.samsung.com/us/video/home...er/HT-D5300/ZA
manual: http://downloadcenter.samsung.com/co...A_CMS_0126.pdf
The problem is that this isn't like a typical reciever in which there are multiple HDMI in's and a HDMI out. It simply has a single HDMI out, and a single optical in. This specific HTIB supports ARC, but unfortunately, his TV is about 7 years old and does not(Toshiba rear projection). It has a single HDMI in on the TV and several HD RCA jacks (blue/green/red/white/red). The tv has no optical output whatsoever so the problem is, how do you wire the HTIB to the TV to make it 5.1 through the "receiver"?
Currently, his comcast box is wired via HD RCA jacks, and the HTIB blurray/reciever is hooked to the TV's HDMI in, but there is no sound because he needs to run an optical cord from the TV to the Reciever, BUT his TV does not support optical.
Can anyone help me out so I can help him out?
I am new to Home theaters as of the last 2 years and am not expirienced with optical and RCA because I've only worked with HDMI.
Are there any converters that he can buy that could make it work?
TV Manual: http://static.fixya.com/Manuals/T/To...35CB5D9D32.pdf
luelf21 is offline
post #2 of 6 Old 05-16-2011, 10:39 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi luelf21, just connect an optical cable from cable box to HTIB.
cable box -> component cables (green,blue,red for video & white,red for audio) -> Tv
cable box -> optical cable -> HTIB
HTIB -> HDMI cable -> Tv
JChin is offline
post #3 of 6 Old 05-17-2011, 05:56 AM - Thread Starter
luelf21's Avatar
Do I still need to run the video component cables to the tv from the cable box?
luelf21 is offline
post #4 of 6 Old 05-17-2011, 06:14 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Yes, with the above setup this would allow your friend to watch cable box tv with or without HTIB being on.
JChin is offline
post #5 of 6 Old 05-17-2011, 07:04 AM - Thread Starter
luelf21's Avatar
As for the bluray, no audio cable is needed because the bluray is essentially the receiver so the signal is already there to send to the speakers?
luelf21 is offline
post #6 of 6 Old 05-17-2011, 10:53 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
That is correct.
JChin is offline
Reply Home Theater In A Box
