"click" sound when turning on/off the receiver (Onkyo HT-S3400) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-24-2011, 11:45 AM - Thread Starter
jinjingforever's Avatar
Newbie question:
Just bought an Onkyo HT-S3400. Everything sounds great. One thing I noticed is that when I turn on/off the receiver, I could hear one or two fairly loud "click" sound from inside the receiver. Is this normal? I heard it could be caused by relay clicking? I've double checked all the wires.
Thanks in advance!
jinjingforever is offline
post #2 of 4 Old 05-24-2011, 05:45 PM
iowa-sd's Avatar
i think this is common, i noticed it too on ht s5400 receiver and tx 609
iowa-sd is offline
post #3 of 4 Old 05-24-2011, 06:43 PM
m_vanmeter's Avatar
usually the "click" is a relay switching the amplifiers into contact with the speaker outputs. This prevents an equally loud and distorted "pop" from going to each speaker as the amplifier circuits fire up, or turn off.
m_vanmeter is offline
post #4 of 4 Old 06-02-2011, 12:42 PM
mikepier's Avatar
Quoted: 16 Post(s)
Originally Posted by jinjingforever View Post
Newbie question:
Thanks in advance!
Yes its normal. I have the HT-S3400 and a HT-S3200. They both do the same.
mikepier is offline
Reply Home Theater In A Box
Onkyo Ht S3400 5 1 Channel Home Theater System
