Uprgading my Onkyo HT-R550 need advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-30-2011, 11:01 AM - Thread Starter
Coopx's Avatar
I just pulled the trigger and bought a new Epson 8350 (my first projector) now i am planning to upgrade my sound system, currently i have Onkyo HT-R550 HTIB system but it doesnt decode true HD dolby/dts. Do you guys have any suggestion on what should i replace with my onkyo, my budget is $300-$400 max.
Or if you have any suggestion for just the reciever, cuz i think i can just keep the speakers on my R550 system.
Coopx is offline
post #2 of 4 Old 08-02-2011, 01:30 PM
gspfunk's Avatar
For $400, you can get the Onkyo 5400 or maybe one of the Denon HTIB's. If you just need a receiver, watch Fry's and some of the other places for specials. I nabbed the Onkyo RC360 for 250 at Fry's 2 weeks ago. It replaced the R580 that came w/ my S5300 HTIB. The difference is amazing.
Check some of the other threads for some more options. A lot of people are looking for the same thing....that may be why no one's replied yet.
Vanns, B&H Photo, or J&R are great places to price some systems or just receivers as well.
gspfunk is offline
post #3 of 4 Old 08-10-2011, 08:54 PM - Thread Starter
Coopx's Avatar
i have a question, do i really need a 7.1 system? i was checking the back of my blurays and most says 5.1 DTS-HD
Coopx is offline
post #4 of 4 Old 08-10-2011, 09:24 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Yes, very few discs have 7.1 tracks. But, you can matrix 5.1 into 7.1. So, if you have a room that works for 7.1, go for it.
BIslander is offline
Reply Home Theater In A Box
