Onkyo HT-S8400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-28-2011, 05:50 PM - Thread Starter
The_Sn1p3r's Avatar
Hello
I recently bought this HTiB about 2 days ago and loving every single moment and not looking back. This system show exactly how surround sounds make a difference. I was playing Black Ops and each shot from various weapons have their own sound and echo, man, try out the LG sniper rifle, that echo really sounds how powerfull and awesome that gun really is. Well, enought about that, I came in here because the receiver can produce Pro Logic IIz, but there seems no way on how to enable it, I have tried different things but its still ghosted, I have the 7.1 speakers already hooked up and working fine, but with PLIIz you can turn it into 9.1, I had already dont this with my previous system, but i cant seem to "enable" this receiver to pick it up or change it to, the word is ghosted and you cant "click" or "enable" it. Anyone know how to enable it?
Thanks!!
The_Sn1p3r is offline
post #2 of 8 Old 10-28-2011, 06:18 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Originally Posted by The_Sn1p3r View Post
I came in here because the receiver can produce Pro Logic IIz, but there seems no way on how to enable it, I have tried different things but its still ghosted, I have the 7.1 speakers already hooked up and working fine, but with PLIIz you can turn it into 9.1, ...
Thanks!!
Hi The_Sn1p3r, the S8400 is a 7.1 channel receiver and not 9.1. You can only do up to 7 channels (7.1) at any one time. You get the standard 5.1 channels which is Front Left & Right, Center, Surround Left & Right, Subwoofer and with an option of either Surround Rears or Front High. You can not have 7.1 plus Front High (9.1) playing all at the same time (see page 12 in OM).
JChin is offline
post #3 of 8 Old 10-28-2011, 08:15 PM
Otto Pylot's Avatar
Quoted: 1381 Post(s)
Liked: 866
You can't make it do more than what it's designed for. RTFM.
Otto Pylot is offline
post #4 of 8 Old 10-28-2011, 08:38 PM - Thread Starter
The_Sn1p3r's Avatar
ok, lets say i wont be able to do 9.1, what about PLIIz, how would i turn it on?
post #5 of 8 Old 10-28-2011, 10:03 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Do you have Zone 2 enabled? If so set Zone 2 to "No" and this should allow the option to select "Front High".
JChin is offline
post #6 of 8 Old 01-18-2013, 02:19 PM
chong67's Avatar
I did the Firmware upgrade that is about 6 months old and BOY, it sould so much better! Now I can really fell the 7.1 speakers from the side and back!
chong67 is offline
post #7 of 8 Old 12-25-2014, 10:01 PM
chong67's Avatar
This Receiver is terrible. It died on me after 3 yrs of use!
chong67 is offline
post #8 of 8 Old 12-25-2014, 10:13 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 273
contact Onkyo as it may be under a recall.
Who needs 4K?... just go see your optometrist.
NODES is offline
Reply Home Theater In A Box
