Best 2.1 - AVS | Home Theater Discussions And Reviews
post #1 of 14 Old 11-13-2011, 01:24 PM - Thread Starter
shahrock's Avatar
I have to buy a 2.1 and need to choose from the following options i came up with after little research:
1. Bose cinemate -II
2. Yamaha YMC-S21BL
3. Onkyo HTX-22HDX Ultra-Compact HD Home Theater System
Please advise.
shahrock is offline
post #2 of 14 Old 11-13-2011, 04:12 PM
wowyahoo's Avatar
out of those three my vote is for...
However, what is your budget?
wowyahoo is offline
post #3 of 14 Old 11-13-2011, 05:41 PM - Thread Starter
shahrock's Avatar
<= 500
shahrock is offline
post #4 of 14 Old 11-13-2011, 07:46 PM
wowyahoo's Avatar
Bowers Wilkins 685
http://www.modia.com/Bowers_Wilkins_...er_p/685bk.htm - $325
Pioneer VSX-520-K 5.1 - $140
http://www.amazon.com/Pioneer-VSX-52...241867&sr=1-12
and add a sub later
OR
LAVA LSP08 - $167 (after AVS forum discount)
http://www.lavasubs.com/8_inch/power...subwoofer.html
Yamaha NS-333 - $190
http://www.amazon.com/Yamaha-NS-333-...1242241&sr=1-3
Just somthing to think about!
wowyahoo is offline
post #5 of 14 Old 11-13-2011, 08:17 PM - Thread Starter
shahrock's Avatar
I think thats a very good option, thank you very much.
Just two doubts:
- is pioneer receiver worth it or should i look for onkyo or denon ?
- is Yamaha speaker worth it (given its 2 yrs old model) or should i look like def tech, klipsch or polk etc ?
shahrock is offline
post #6 of 14 Old 11-13-2011, 10:51 PM
saiko's Avatar
Just two doubts:
It's worth it. This years model is on sale on amazon for 299
saiko is offline
post #7 of 14 Old 11-14-2011, 10:28 PM - Thread Starter
shahrock's Avatar
Is this beatable, in this price range ?
P.S I dont need 3-d or internet ready features
Yamaha NS-333 2-Way Bass Reflex Bookshelf Speakers
$189.95
Energy ESW-M6 800 Watt Mini Subwoofer
$199
Pioneer VSX-920-K 7.1 Home Theater Receiver
$ 245
I will upgrade if needed with a polk center some time ahead.
shahrock is offline
post #8 of 14 Old 11-15-2011, 02:32 PM
wowyahoo's Avatar
$189.95
$199
$ 245
yes, it is. spend more on speakers and less on the receiver.
In addition, you want the front 3 speakers to be matched by the same line (timbre matching). So, if you get the Yamaha NS-333 you need to get the matching center (Yamaha NS-C444).
wowyahoo is offline
post #9 of 14 Old 11-15-2011, 03:47 PM - Thread Starter
shahrock's Avatar
thanks a lot.
I got it, so the 3 speakers would be yamaha (or if you have any such gud, not much expensive alternative), sub would either be lava or energy , wht sort of receiver should i luk at ?
shahrock is offline
post #10 of 14 Old 11-15-2011, 04:15 PM
wowyahoo's Avatar
thanks a lot.
I'd go for the Pioneer VSX-521-K 5.1 for $180 at newegg
speakers could be...
polk rti4 same as Polk RTi A1 (better than polk TSi series you see at bestbuy) - $150
http://www.ebay.com/itm/PAIR-RTi4-CH...item53e9fe7a87
LAVA LSP10 Subwoofer for about $210 after AVS 15% discount.
http://www.lavasubs.com/10_inch/powe...subwoofer.html
wowyahoo is offline
post #11 of 14 Old 11-15-2011, 04:32 PM - Thread Starter
shahrock's Avatar
so the receiver & sub is finalised.
Reading about speakers, isnt yamaha ns-333 ones better than polk rti4 ?
shahrock is offline
post #12 of 14 Old 11-15-2011, 05:58 PM
wowyahoo's Avatar
I have the RTi series and enjoy them. Honestly, I would go to bestbuy and listen to the Polk TSi line and if you like the sound you will like the RTi series better.
EDIT: When you wish to purchase a center, the CSi3 or CSi A4 (same thing) would be a proper match.
http://www.crutchfield.com/p_107CSI3...sh.html?tp=189
wowyahoo is offline
post #13 of 14 Old 11-16-2011, 08:05 AM - Thread Starter
shahrock's Avatar
choosing refurb- can get denon from dakmart , HK from ebay, both ~250-280
I think its better of than going for new pioneer, yamaha, onkyo etc, especially after going through various posts in this forum.
Please advise out of HK or denon as above.
shahrock is offline
post #14 of 14 Old 11-16-2011, 09:05 AM
wowyahoo's Avatar
Go with whatever features you need/want. The difference in sound quality between the receivers will be negligible. Good luck!
wowyahoo is offline
Reply Home Theater In A Box
