Onkyo HTS3400 vs Denon DHT-391XP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-21-2011, 10:26 AM - Thread Starter
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
Comparing these two HTIBs, any recommendations for one over the other?
I read up some threads on these two, but no direct comparison. I am looking at these two models only at this time as I can get a deal on them. Third option would be to skip em both and build my own combination for 200/300 more down the line.
Never done an audio before so HTIB seemed like a good basic start.
aliaskary77 is offline
post #2 of 12 Old 12-22-2011, 12:18 AM
pokekevin's Avatar
Quoted: 12 Post(s)
Liked: 102
I used to have the 391 and was pleased with it. Howmuch are they going for? Max budget? Room size? Goal?
pokekevin is offline
post #3 of 12 Old 12-22-2011, 05:42 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 56
would like to stay in the 300-400 range. working temporarily for a big box store so trying to make use of savings.
i did pick up the 391 but man is that box heavy. have not opened it yet. double minded.
i am also now looking at "Pioneer 5.1 Channel 3D Home Theatre Receiver with Polk Audio 5.1 Speaker System". The receiver is the VSX-521-K. I think the speakers are the RM6750.
Room size typically 11x17. Just want something other then the flat screen speakers. Entry level to enjoy 5.1. Soundbar was a consideration but dont know how they would fair.
thanks.
post #4 of 12 Old 12-22-2011, 08:14 AM
Elihawk's Avatar
Quoted: 1323 Post(s)
Liked: 1157
Neither Onkyo or Denon is know for making even average speakers...so the deal with the Pioneer receiver and Polk speaker set will likely give you a much better sound.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is online now
post #5 of 12 Old 12-22-2011, 08:44 AM
afrogt's Avatar
Quoted: 1357 Post(s)
Liked: 940
except when you factor in all the video problems with the Pioneer vsx-521. Check the 521 owners thread in the amp & receivers section.
http://www.avsforum.com/avs-vb/showthread.php?t=1321970
Afro GT
afrogt is offline
post #6 of 12 Old 12-22-2011, 09:17 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 56
If I keep the RM6750 speakers, what other receiver in the 250-300 range should i look at then? (Pioneer 821 could be an option as well, but dont know if they would have the same problems.)
post #7 of 12 Old 12-22-2011, 10:24 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
That's easy, the Denon Avr-1612 http://www.amazon.com/gp/aw/d/B004U403WM
crazyrob425 is offline
post #8 of 12 Old 12-22-2011, 10:33 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 56
lol ok now im going away from where i first started.
denon 1612 could be an option.
now speakers.
stick with the RM6750 set
or go with
R300 fronts R150 srounds, cs1 center, and (dont know which subwoofer yet.) they arent that expensive as i thought.
post #9 of 12 Old 12-22-2011, 11:16 AM
Quoted: 443 Post(s)
Liked: 337
What is your budget including receiver? We might know of deals you don't.
post #10 of 12 Old 12-22-2011, 12:28 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 56
crazy, will pm you.
post #11 of 12 Old 12-23-2011, 08:41 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 56
denon 1612 and rm6750 it is then. thanks all.
post #12 of 12 Old 12-24-2011, 07:17 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 56
arrgghh! was almost set to buy the stuff, but another very comparable (cost to me) setup was suggested.
denon 1612 or Pioneer VSX-921-K?
Polk RM6750 or Energy Take Classic II 5.1 Speaker System?
Reply Home Theater In A Box
