Onkyo SKS-HT870 vs SKS-HT540 7.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-23-2011, 01:42 PM - Thread Starter
imarichards's Avatar
hello ,
I am leaning towards either one of these due to the price range.
I need help in comparing both so i can decide on one. After looking at the product description from amazon I could not figure out the actual difference between these two other than the look. please help
Onkyo-SKS-HT540-Channel-Theater-Speakerr
vs
Onkyo-SKS-HT870-Theater-Speaker-System
imarichards is offline
post #2 of 6 Old 01-03-2012, 01:13 PM
asmealio's Avatar
Quoted: 17 Post(s)
I've got no love from the forum either on this topic...I'm in the same predicament and am curious as to what is better.
Did you end up making a decision?
asmealio is offline
post #3 of 6 Old 01-03-2012, 04:56 PM
pokekevin's Avatar
Quoted: 16 Post(s)
Liked: 102
Other than the tower I don't or can't tell the difference! Ill look into it when I get home.
pokekevin is offline
post #4 of 6 Old 01-05-2012, 12:48 PM
asmealio's Avatar
Quoted: 17 Post(s)
I jumped on the 870 set, i'll let you know how they work out
asmealio is offline
post #5 of 6 Old 02-29-2012, 04:38 AM
pkav's Avatar
What speaker stands did you use for the 4 surrounds? What type of options does Onkyo give to attach the surrounds to speaker stands? I know there are different ways usually for regular speakers to attach to stands (e.g. screw holes underneath the speaker; screw holes on back of speaker, etc).
Which way did Onkyo have their surrounds set up to attach to speaker stands.
This will help me out as I'm trying to decide on the SKS-HT870.
pkav is offline
post #6 of 6 Old 03-07-2012, 05:26 AM
asmealio's Avatar
Quoted: 17 Post(s)
I got some sanus hand me downs from a buddy of mine. They are pretty solid. However, because the mount on the Onkyo's are on at the top on the back's of the speaker, and given the size of the surrounds...I had to mount mount them backwards..basically the bend in the stand goes the other way to cater to the size of the speaker.
asmealio is offline
Reply Home Theater In A Box
