Sony BDV-E780W Cable Connections - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-11-2012, 05:41 AM - Thread Starter
cgnday's Avatar
Hi. It's my first here.
I just bought this home theater system to use with my LG 55LX9500 Full Led TV. I want to get the sound of my PS3 and my satellite receiver with it.
My connections right now are:
PS3 to TV -> HDMI
Satellite Receiver to TV -> HDMI
E780W to TV -> Optical
Is this setup correct to get the highest quality audio and visual? If not, could you share other options please?
cgnday is offline
post #2 of 6 Old 01-11-2012, 08:17 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi cgnday, suggested connection.
PS3 -> HDMI cable -> Receiver HDMI IN-1
Satellite Receiver -> HDMI cable -> Receiver HDMI IN-2
E780W -> HDMI cable -> TV
TV -> Optical cable -> E780W Digital Optical In (TV)
JChin is offline
post #3 of 6 Old 01-11-2012, 08:51 AM - Thread Starter
cgnday's Avatar
thanks JChin.
Any ideas about the PS3, TV and 780W settings?
cgnday is offline
post #4 of 6 Old 01-11-2012, 09:47 AM
YTRY's Avatar
thanks JChin.
Regarding the PS3 under the settings menu select audio then HDMI and finally Auto Detection. The PS3 will then "talk" to the receiver and set the audio output to match what your receiver can do. You will then be asked to confirm the settings and your done.
YTRY is offline
post #5 of 6 Old 01-11-2012, 05:04 PM
Mitchgrant's Avatar
Jchin, can I bug you about my Sony bdv-e580?
It takes me five minutes to watch tv every time I turn it on.
Mitchgrant is offline
post #6 of 6 Old 01-16-2012, 01:02 PM
dengland's Avatar
Quoted: 21 Post(s)
You can have it go into standby instead of powering down. It should be in one of the menu options. If you have trouble finding it, write back.
EDIT: See page 61 and 62 of the manual.
dengland is offline
Reply Home Theater In A Box
Sony Bdv E780w Blu Ray Disc Player
