LG LHB975 wireless speaker sync repair - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 97 Old 10-15-2013, 04:06 PM
idcrisis's Avatar
Did anyone else receive a notice regarding a class action lawsuit?
idcrisis is offline
post #92 of 97 Old 11-25-2013, 03:44 PM
fmahannah's Avatar
I know this is an old post but it is the only one I found that actually showed a fix for the issue with the LG LHB975.
Mine stopped synching about 6 months after I got it. Sent it for repairs and it worked for about 3 months. Since that time it has not worked. Neither the subwoofer or the rear receiver showed anything but red after trying to remate. Neither set of speakers or subwoofer make any sound at all. The front speakers and center speaker work fine.
Found this post and tried swapping the card from the rears into the subwoofer, made no difference. Figured both cards were shot.
Ordered two new cards from Sears, and they only sent me one. Backordered the other.
I have tried every possible combination and have no luck at all. Figured I would try to just get the
subwoofer to work by itself, swapping each card into it one at a time and remating per instructions. I also tried shutting off the main unit, holding the power button for 30 seconds, and plugging it back in before each remate attempt.
Here are my results:
1. The card that was in the rear receiver and has never been changed shows FW version 1.0.5.6
2. The card that had been replaced by LG in the subwoofer shows FW version 1.0.6.3
3. The new card from Sears says FW version 1.0.6.4
If I put the first card into the subwoofer, and go through the entire hard reset and remate procedure,
when I plug the subwoofer in there is no light whatsoever.
If I put the second card into the subowwofer, hard reset and remate, the light flashes blue like ten times
and then turns and stays red.
If I put the new card in the subwoofer, reset and remate, the light continually flashes red/blue ten times,
glows blue for a moment, then goes throught this cycle again indefinitely.
At no time do I get any sound from the subwoofer. No matter what I do.
I assume that since the subwoofer won't even light up with the card from the rear speakers (the old one) that it means that card is bad, but if that was true wouldn't the subwoofer had still had sound with the card LG had put in it. Or if they don't synch does it turn off the subwoofer and the rear speakers?
Any ideas what is wrong here?  I also ordered a replacement transmitter today in case that is why neither set of speakers will work, but won't have that or the backordered card for a while.
fmahannah is offline
post #93 of 97 Old 12-09-2013, 07:07 PM
bruckins's Avatar
Jerseyfind.
Thanks bro I swapped The woofer card with the receiver and my woofer started working. Now I have to order a new card for the receiver.
bruckins is offline
post #94 of 97 Old 01-26-2014, 10:48 AM
Legendmustang's Avatar
Ok I have read through this hole section and I don't see the help I need. Both my rear speaker and subwoofer do not connect. Could this be the wireless card in that actual head unit or both cards in the rear?
Legendmustang is offline
post #95 of 97 Old 06-13-2014, 11:37 PM
Liked: 0
LG LHB 975 wireless issue
Yes, I got the class action notice. Unfortunately, the only benefit is extension of the warranty which requires shipment to LG. The owner's manual says, save the box to ship back but I got the unit in 2010 and long since tossed the box. Actually, I just read the class action notice and realized that I've been wondering about the red circle on the rear speaker receiver and thought it was because I haven't been watching Blu Rays and so the unit wasn't sending surround sound signals.
Does anyone know how to open up the wireless receiver for the rear speakers? I undid the screws in the midline and one of the side screws in back, but 2 edges of the box won't open.
Ffoeg is offline
post #96 of 97 Old 07-29-2014, 07:03 PM
PRAY4WAR's Avatar
Liked: 0
Same problem here. Front & Center speakers work fine. The subwoofer & the rear speakers went out at exactly the same time. I tried all the remating processes known to man, and nothing works. Funny thing is I just got the unit back from LG about 2 months ago, they said they "fixed it" after I sent it in because my subwoofer's wireless card went out. This surround sound system is by far the worst piece of junk I've ever bought in my life. Never again will I buy ANYTHING LG.
PRAY4WAR is offline
post #97 of 97 Old 07-31-2016, 01:33 PM
Liked: 0
LG LHB975 No rear spkrs, no subwoofer
I have an LG LHB 975 Home theatre system. Rear speakersstopped working about 9 months ago and the subwoofer stopped working about 3months ago. Remating has done nothing to solve the problem. Looks like the cards (EBR65859702),areprobably bad and need to be replaced. Would replacing the one card in thewireless receiver fix the problem for both the speakers and subwoofer. Light on the subwoofer is steady blue, eventhough there is no sound. Light on the receiver remains red. Remating has not been successful for either.
JMacDaddy is offline
Reply Home Theater In A Box
Lg
