Need help in setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-14-2012, 07:03 PM - Thread Starter
eacollie's Avatar
Hi:
I have a system that has been working OK for awhile, but I need to make a change and can't seem to figure out how to do it. Any help would be greatly appreciated!
I have a Panasonic SA-HT940 surround sound (SS),
Samsung DLP TV and
ATT Uverse cable box.
The problem I'm having is that I get a "mode not supported" when watching TV. I've searched and discovered that this may be due to a setting on my surround system (SS) to use the "i" signal when it should be set to accept "p" signal. The problem is that I cannot access the menu to the SS to make the change.
Thanks for any help!
eacollie is offline
Reply Home Theater In A Box
