Insignia HTIB no video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-17-2012, 11:43 PM - Thread Starter
ptstek's Avatar
I'm having a strange problem. I retired a less than a year old Insignia HTIB, the 5.1 with a large sub, and a friend wants it. It worked perfectly for me, just wanted to upgrade. His TV is an LG 42k520 LCD. It won't put video out on HDMI or composite when fed HDMI from the receiver. I brought the receiver back to my place and verified it works fine with my Panasonic TVs. Back at his house the PS3 slim won't come up on the TV, and Directv on composite doesn't appear but we have sound only. I did not try the composite connection on my equipment.
What could be going on here? I did configure the input properly and select the source- I can't see anything else that I'm missing. It should be stupid simple. Did a firmware update on the LG since one was available with no change. Of course, direct connections to the LG work normally. The Insignia GUI comes up on the TV, just not the source material.
ptstek is offline
post #2 of 5 Old 01-19-2012, 11:53 PM - Thread Starter
ptstek's Avatar
No ideas?
ptstek is offline
post #3 of 5 Old 01-20-2012, 05:14 AM
toofarzong's Avatar
It sounds like the settings on the TV aren't configured correctly. If I were you I'd double check the TV settings.
toofarzong is offline
post #4 of 5 Old 01-21-2012, 09:54 AM
YeuEmMaiMai's Avatar
does the TV give you any messages like "source not valid"?
also is there are firmware update that addresses this issue on the TV (ie HDMI pass through does not work)
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #5 of 5 Old 01-21-2012, 05:24 PM - Thread Starter
ptstek's Avatar
Just 'no signal' floating around on the tv screen. Bypass the receiver and plug it in directly, works fine.
I don't really know what other settings on the tv there could be. We looked at all of them, just selecting the right hdmi input should be all it wants.
POS LCD's
ptstek is offline
Reply Home Theater In A Box
