Apartment HomeTheater Advice Needed - AVS Forum | Home Theater Discussions And Reviews
Old 01-26-2012, 06:18 PM - Thread Starter
mraeder2012's Avatar
Just bought a 55" LCD 1080P 120Hz TV and a PS3. Both will be going into my apartment living room (13'8" X 12/'9" == TV will be 8'-8.5' from couch). As far as audio, what are some value, i.e. biggest bang for the buck is should be looking for -- $100-300? SoundBar and Receiver? HDMI input/output? Essentially, I am looking for ease of set-up with the best sound quality for the money and I would like to run everything through the same receiver (TV, PS3, DirectTV/UVerse, SoundBar or Speakers, etc.) Can you recommend to me a couple options and the pros/cons of each? Thanks so much for your time!
mraeder2012 is offline
