Yamaha YHT196 vs Onkyo HT-S3400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-10-2012, 01:01 AM - Thread Starter
chroncile's Avatar
Hi, I recently purchased the Yamaha YHT-196 and I have had it for less than a day now and so far it seems to be good. This is my first home theater system.
I could not find any reviews online for the Yamaha YHT-196, but I did find a lot of reviews for the Onkyo HT-S3400 and it was a mixed response. A lot of people found the Onkyo system to be amazing while others complained it either sounded worse than previous home theater systems they owned or the Onkyo speakers started to sound staticky after 2 weeks of use. Some even said their Onkyo HTiB died after less than one month of use.
I also went in store to hear the Onkyo HT-S3400 and it sounded very dull to me. No matter how loud I put the volume up, it still sounded very bad and such I decided to buy the Yamaha YHT-196.
Which one is better? The Yamaha YHT-196 or the Onkyo HT-S3400? The only difference I found was the Onkyo receiver supported Dolby TrueHD while the Yamaha one did not.
What do you think? Should I return the Yamaha HTiB and buy the Onkyo one or should I stick with the Yamaha one?
chroncile is offline
post #2 of 5 Old 02-10-2012, 03:44 AM
YeuEmMaiMai's Avatar
Yamaha does not have the build issues that Onkyo does so that is a giant plus......
speakers are 2.7" (7cm) full range acoustically sealed plus 1 sub that is 6.3" (16cm) bass reflex (ported)
rated power of receiver is 100W 1Kz 1 channel driven
http://uk.yamaha.com/en/products/aud..._g/?mode=model
retail is $199 brittish pounds
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #3 of 5 Old 02-13-2012, 03:36 PM - Thread Starter
chroncile's Avatar
Okay so it's been around 3 days now since I purchased the Yamaha YHT-196 and so far, it hasn't blown me away like I expected it to. I'm using it for watching movies on my PS3 and playing PS3 games. I did setup the speaker distances and volume, but the only thing that's different from my tv speakers is the bass; the Yamaha HTiB delivers a relatively good bass.
Am I doing something wrong? I was sure that a HTiB would blow away any TV speakers.
Also, I think the Yamaha receiver isn't able to decode 5.1 PCM. Using my PS3, I was not able to hear 5.1 audio from the XMB menu and from the videos that play when you are selecting a game to play. After I disabled 5.1 PCM and kept Dolby Digital and DTS on, I could hear 5.1 audio from the XMB menu which is weird because even with 5.1 PCM on, the Yamaha receiver displayed 5 speakers on its screen. By the way, I have my dsp mode set to straight.
Another thing, when I go to the options menu and display the input info, it shows 3/2/0.1 in the channels part. Why is this?
post #4 of 5 Old 10-12-2012, 10:33 PM
rmahore's Avatar
Hi,
I am planning to purchase YHT-196 and want to connect with my panasonic plasma. Please suggest if this is good buy..
Raju
rmahore is offline
post #5 of 5 Old 10-13-2012, 11:02 AM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
Originally Posted by rmahore View Post
Hi,
Raju
I would look at the YHT-395/396 instead. More features with an active 8" sub. The speakers are ok for what they are buy you may want to just buy the receiver separately and spend a little more on better speakers. I have the YHT-395 and have been very happy with it.
Otto Pylot is offline
Reply Home Theater In A Box
Onkyo Ht S3400 5 1 Channel Home Theater System
