klipsch set up - AVS Forum | Home Theater Discussions And Reviews
Old 02-15-2012, 06:24 PM - Thread Starter
gosugadget's Avatar
I was going to get a decent set up with the klipsch line and want some advice.
Is the home theater set up 5.1 fine? (Klipsch HD Theater 500 5.1 Home theater Speaker system with powered subwoofer)
They also had book shelf speakers/floor speakers/ and subwoofers speakers. I'm not a audio expert and my living room is about 30 feet by 20 feet. Will I need additional or just one of the other or both?
gosugadget is offline
Old 02-15-2012, 07:22 PM
TheCableMan's Avatar
I don't have the klipsch 5.1 system myself but FWIW Best Buy has the klipsch icon bookshelf speakers onsale this week. Normally 249 now 149 for a pair. I picked myself up a set to replace some crappy towers and I couldn't be happier with them. I did have to shut my old crappy center off and have the klipsch phantom the center because the difference between the center and the klipsch was horrible.
Always Up for a Good Zombie Flick
TheCableMan is offline
Old 02-15-2012, 11:48 PM - Thread Starter
gosugadget's Avatar
thanks. I think i'll go with the 5.1's and one of the one's you just mentioned.
