ONKYO HT-S9400 THX 7.1-Channel HTIB - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 156 Old 04-25-2013, 08:30 PM
DonQuixote100's Avatar
I bought a 9400thx from Newegg on special for $599, no S/H cost as I picked it up. Been enjoying, 1st thing I did was upgraded wire to 14g wire and added banana clips to connect to the amp.
Girlfriend Freaked at the size of the speakers(her house)eek.gif....but since I'm building in the entire wall to fit a 70" Sharp and all the other electronics/speakers etc....that has softened the blow....cool.gif
Now for the Sacrilege....I got older style(heavier than "Redline") Bose dbl cubes for my back speakers to replace the monster Onky's....Use the audyss setup and frankly...it sounds pretty good...and the peace at home doesn't hurt either!!...however, there is that little matter about the side speakers...so stay tuned...
DonQuixote100[/SIZE
R]
Isn't it true that the only time you have ever really benefited from
anything in your life was when you said " Yes " instead of " No "?[[
CENTER]SIZE]
Isn't it true that the only time you ever really benefitted
from anything is when you said YES instead of NO??[[[
/CENTER]/I]/SIZE]
DonQuixote100 is offline
post #92 of 156 Old 05-05-2013, 05:47 PM
HogFan2's Avatar
For those if you that are currently running the 9400, it sounds like the set up is great for bluray movies, but what about general stereo listening? Does the thx mode ruin this, or dies it just automatically switch off during certain modes like radio tuner?
HogFan2 is offline
post #93 of 156 Old 05-05-2013, 10:11 PM
hdfatboy2003's Avatar
Quoted: 26 Post(s)
I've had mine for a little over 2 months now. I love this setup, despite the speakers being larger than I anticipated. (So much for visualizing their size - maybe I need a better tape measure ... smile.gif ) You can set the listening mode for each different connections, e.g. TV, BluRay, Tuner, iPod, etc. I have mine all set for THX Cinema. It sound the best to me as the THX Cinema kicks in the Read Surrounds and I like the music coming from all sides.
hdfatboy2003 is offline
post #94 of 156 Old 05-13-2013, 11:40 PM
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
Thinking about buying this, just had a question about HDMI cables. I'm still using a 12 year old reciever with no HDMI inputs. I use optical cables. If I want to do away with the optical cables for my PS3 and XBOX and get all sound and picture only from HDMI cables, how does this work? Will any HDMI work, or do I need a certain version? The current version is 1.4 I believe. Not sure what type mine are. Is there any benefit to switching from optical to HDMI other than having less cable mess?
bassage is offline
post #95 of 156 Old 05-14-2013, 01:03 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
I am assuming you are thinking of buying the Onkyo S9400 HTIB. There are only 2 HDMI cable ratings high speed and low, that has more to do with gage and length. The 1.4 is a version number that has to do with the HDMI components used in audio/video gear. The Onkyo 9400 is a nice set that engineered to work with HDMI. For more information on on HDMI there are 2 vendors with links at the bottom of page that have a lot on offer about cables, Monoprice.com and bluejeanscable.com.
Phil17108 is offline
post #96 of 156 Old 05-14-2013, 02:17 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
HDMI supports high-res lossless codecs, such as TrueHD, and multichannel PCM. Optical is limited to the lossy codecs and stereo PCM.
When it comes to audio, any HDMI cable will do. High speed cables are recommended for 1080p video and 3D, although standard cables will often work for those features, too, especially over short distances. Just get high speed cables and you'll be good to go for everything. HDMI version numbers do not refer to cables, btw. They describe the functions of the transmitting and receiving equipment, not the cables connecting them.
BIslander is offline
post #97 of 156 Old 05-14-2013, 09:23 AM
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
Thanks. Just checked, and saw the specs for my cables. I have these cables, http://www.amazon.com/gp/product/B0031TRZX2/ref=oh_details_o03_s00_i01?ie=UTF8&psc=1
Looks like they will do fine.
bassage is offline
post #98 of 156 Old 05-14-2013, 09:59 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Yes, those cables will be fine. The Ethernet part has no use at present as there are no consumer devices that support Ethernet over HDMI.
post #99 of 156 Old 07-23-2013, 08:45 PM
Brad Bonnell's Avatar
anybody have an idea, of how I could mount the front left and right speakers above my screen sideways, while still being able to point them at me, can I move the brace to the middle of the speaker and just buy a heavier mount, or use two mounts somehow????
Brad Bonnell is offline
post #100 of 156 Old 07-24-2013, 08:37 AM
flickhtguru's Avatar
Liked: 110
If at all possible you don't want to mount them horizontally. Placing an MTM speaker horizontally really messes up its dispertion (radiating) pattern. In a perfect ideal world you would have an acoustically transparent screen and you would mount 3 identical vertically oriented speakers behind the screen with the tweeters at seated ear level.
Do you have any other placement options?
Shawn
flickhtguru is offline
post #101 of 156 Old 07-24-2013, 11:24 AM
no not really without making my screen smaller, I know it won't sound the same, but it is the best option. just wanted to see if there was any way to do it that I missed. Was going to buy six L shaped braces and try to angel the speakers on them with wedges.
post #102 of 156 Old 11-21-2013, 05:29 PM
humanbeardog's Avatar
I to am considering this system. I had to part with my Marantz AV7701 and pro audio monitors so this seems to be a good re-starter system that you can build off of. If I get it the sub will go and be replaced with a pair of SVS SB13 Ultra's. I care more for music reproduction so I'd like to know how it performs in that catigory.
humanbeardog is offline
post #103 of 156 Old 11-26-2013, 05:49 PM
wili's Avatar
hi, i buy a ht.9400 thx, and the tweeter burned, and i need now usa shop, to buy a new one, if now some shop please notice me. please,
thank`s
wili is offline
post #104 of 156 Old 11-26-2013, 08:17 PM
Daniel Chaves's Avatar
Quoted: 393 Post(s)
Liked: 280
well I replaced my front stage with Polk Audio, my sides and rear are still the Onkyo THX speakers.
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS/DTSX + Darbee 5000
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.2 Source: HTPC, Roku 4, Nexus Player, Samsung UBD-K8500 4k Bluray Player
Daniel Chaves is offline
post #105 of 156 Old 11-27-2013, 06:05 AM
Wili, depending on the age and if you bought it from an authorized dealer it may be under warrenty. Go to http://www.onkyousa.com/ and find an authorized repair shop. But honestly those speakers are cheap to make the unit as a whole affordable. Just replace the whole speaker. Less headache and you can get what you really want.
post #106 of 156 Old 11-27-2013, 08:50 AM
Liked: 110
^^^ Acually those speakers are not bad speakers at all... I have installed 2 different Onkyo THX systems for ppl and they sound really good for the price. Honestly I like the sound of the Onkyo THX speakers better than the Klipsch Icon or Synergy Series and better than Polk Monitor 30s.
Wili I would contact Onkyo and see what they will do about it. See if you can buy a replacement speaker if they won't fix it...... The bad thing about trying to just go buy a Polk or a different speaker to replace that one is then if it was one of the front 3 speakers then you should replace all 3 to have matching speakrs. If it was a rear speaker then at a minimum you would need to replace 2 speakers but probably all 4 surrounds.
Shawn
post #107 of 156 Old 11-28-2013, 11:16 AM
SgtCajun's Avatar
Howdy folks, recently grabbed this system for $299 from Newegg's eBay side of things (it's not named that, but in ended up picking it up from their wharehouse in SoCal).
Sounds great so far but I'm having an issue that I assume is simply a setting I'm missing somewhere since I'm a newcomer to the "reciever" game.
I have a Sony BluRay and Xbox 360 both feeding into the reciever via HDMI which feeds to a Vizio E701-A3 via HDMI as well.
The problem is that we are some of those strange people that enjoy the "soap opera effect". When running netflix through the baked in TV app, the effect works fine. When running it through the Xbox or BluRay the effect does not work. It also does not work for BluRay disks.
I've been poking around the settings but haven't been able to make a difference so far.
I reckon I could break the data from video via HDMI to TV and audio vio optical to the reciever but it feels like a lot of work to accomplish a goal.
Thanks for any help and Happy Thanksgiving to those in the US.
SgtCajun is offline
post #108 of 156 Old 12-03-2013, 03:09 PM
turn off the clear motion setting or set to 60hrtz.
post #109 of 156 Old 12-03-2013, 03:11 PM
turn off the clear motion setting or set to 60hrtz. It will help some. Vizio I do believe have the same motherboard as Samsungs I could be wrong. Samsungs and Vizio are notorious for the soap opera effect. I encountered this installing CATV in peoples house. Its in the refresh rate in the TV not the output devices. My opinion LG plasmas are the best tv's I have run across. Your receiver is fine. This can be changed for each input on the TV. Hope that helped.
post #110 of 156 Old 12-04-2013, 04:25 AM
Niroe64's Avatar
Quoted: 18 Post(s)
Liked: 45
Turn Smooth motion all the way up under advanced settings on your vizio. Here are some settings I found in the Vizio E701-A3 owners thread which you can change under the advanced picture options.
Advanced
SME high
RCM precision
Noise reduction low
MPEG off
Color enhancemeny rich
Adaptive Strong
Film auto
off
off
AVR Onkyo 818
Fronts Klipsch RF-62II's
Center Klipsch RC-62II
Sides Klipsch RB-51's
Sub SVS PB 2000
Blu-Ray Sony Ps3 Screen Samsung UN46D8000
Niroe64 is offline
post #111 of 156 Old 12-04-2013, 05:42 AM
Wow don't I feel dumb. I totally misread your post.
post #112 of 156 Old 12-25-2013, 03:13 AM
Niroe64's Avatar
Quoted: 18 Post(s)
Liked: 45
So I have had my 9400 since July now and am enjoying it for the most part. I was wondering how everyone else is doing with theirs and how they have settled in to using it e.g room size, settings and MV (as related to 0 Reference).
My room measures 12 ft. wide by 19 ft. long and 7 ft. high.
Audyssey set levels from -1 to 1.
Distances for speakers are 6 to 9 ft. I sit 7.5 ft from screen/center.
I listen at -15 to -12.
The systems main use is 90% Blu ray 10% music. (Music in 2 channel only). I have been pleasantly surprised as I came from a "Top of the line" Samsung HTIB and the system has made me smile since purchased. I already plan on upgrading in a couple of months though by no fault of the system, I just caught the upgrade bug quicker then I thought I would haha. I was bored and wanted to see if any other fellow Owners had anything to say about this great entry level system into the world of Home Theaters!
AVR Onkyo 818
Sub SVS PB 2000
Niroe64 is offline
post #113 of 156 Old 12-25-2013, 02:16 PM
Quoted: 393 Post(s)
Liked: 280
I have been loving mine and well I still stand behind this being the best Home Theater in a Box option especially for its price point and what you get it from it. smile.gif
Niroe64 likes this.
post #114 of 156 Old 01-19-2014, 07:56 PM
BiggAW's Avatar
Quoted: 492 Post(s)
Liked: 120
It's definitely the best at it's price point. When I got mine I was in an apartment with no room to get good channel separation of the surrounds and rears. Now that I'm in a house, I've got it almost correctly set up (my left surround is too far back, but it can't come forward, as it will be in the path people walk in), and it sounds AMAZING. ESPN games sound especially good, as they mix their audio very well. A lot of TV shows have really crummy surround sound, but when I find something that's good, it sounds AMAZING. My roommates were watching the eggball game tonight, so I watched a couple of minutes of it, and it sounded AMAZING on the THX. FOX did a really good job mixing the sound for it.
BiggAW is offline
post #115 of 156 Old 02-09-2014, 09:23 PM
mcneilms's Avatar
You guys got some good deals. I can't find this system for anywhere near these prices. All at $900+. I just got back from a few years working in Singapore, so I'm a little late for the party. If anyone finds a deal, I would appreciate a PM.
mcneilms is offline
post #116 of 156 Old 02-10-2014, 07:18 AM
Liked: 110
I honestly haven't seen this system available from too many places lately. I'm wondering if Onkyo is working on a new version of it.... If you really want a good deal then you'll need to buy a refurbished unit. Keep checking in at shoponkyo.com (sign up and register as a member) and accessories4less.com as both those sites are authorized Onkyo sellers and sell refurb units.
Shawn
post #117 of 156 Old 02-11-2014, 12:55 AM
Quoted: 393 Post(s)
Liked: 280
Onkyo is indeed working on a new package that will replace this package but I still see no reason yet to upgrade my receiver lol
post #118 of 156 Old 02-11-2014, 05:49 AM
Liked: 110
I wish they would take this system and give it a 7.2 Network Receiver with a minimum of Audyssey Mult EQ and have all 7 speakers be identical just like the front 3 are now and provide vertical and horizontal mounting holes for all of them, AND have 2 of those subs. I think if they would do that and if the street price was like $800 to $900 for the 7.2 system it would probably sell really well.
Shawn
post #119 of 156 Old 02-12-2014, 04:53 PM
Jed1's Avatar
Quoted: 109 Post(s)
Liked: 59
There is a new firmware update (10/18/2013) for this receiver that is only available for download off of Onkyo's website. They state that there was some issues with the Ethernet download so it is not available that way.
Here is the change log for the update and instruction to do it.
http://filedepot.onkyousa.com/Files/own_manuals/Firmware_Update_for_the_TX609_HT360_10_18_13.pdf
Click on the downloads tab that is between Specs and Video.
http://www.onkyousa.com/Products/model.php?m=HT-S9400THX&class=Systems&source=prodClass
Click on the Firmware USB Download tab and save to your computer.
Latest Firmware Version: 1141-1700-0010-9107
Daniel Chaves likes this.
"You lose it in here you're in a world of hurt"
Jed1 is offline
post #120 of 156 Old 02-17-2014, 06:28 PM
BiggAW's Avatar
Quoted: 492 Post(s)
Liked: 120
You need bigger front channels than the surrounds... the fronts are driving the audio while the surrounds are doing just that... surround. Also, most people don't need two subs. My guess is making a 4k-ready version with some other minor tweaks. I'm sure it will still be an excellent setup!
BiggAW is offline
Reply Home Theater In A Box
Onkyo , Onkyo Ht S9400thx 7 1 Channel Network A V Receiver Speaker Package , Onkyo Tx Nr900 Thx Select 7 1 Channel Digital Surround Receiver , Speaker Systems
