Suggestions for a compact system - AVS Forum | Home Theater Discussions And Reviews
Old 03-14-2012, 12:00 PM - Thread Starter
yosoyamar's Avatar
Hello all,
I am in the process of setting up a "real" media/entertainment room in my basement. As I move my higher-end but bulky components to the entertainment room, I need a compact replacement system for my family room. Ideally, I need:
* A compact system, since my family room is relatively small, about 12x15
* A real 5.1 system -- not sure I could live with simulation via a sound bar after having had a decent (Acoustimass 10) system for many years. The front speakers can be included in a sound bar as long as there are separate rear speakers. Ideally, rear speakers would be slim and floor-standing, to avoid need for a separate stand or wall-mounting.
* Included DVD player and receiver (DVD player not a must-have)
* Several HDMI inputs
* In-built wireless internet connectivity, including at a minimum Netflix connectivity (no adapters)
* Wireless rear speakers and subwoofer (no adapters)
* Built-in iPod connectivity or Bluetooth availability
* Sound can be decent but need not be great
* Priced under $600
So far, the only system I have come across that comes even close to these requirements is Panasonic SC-BTT770. A couple of things I don't like about the BTT770 are: (1) The front speakers are somewhat large, and (2) The subwoofer isn't wirelessly connected.
Please let me know if you have any other suggestions for systems that fit the bill.
yosoyamar is offline
Old 03-16-2012, 04:11 PM
smoke90's Avatar
I am also in the same search as you. Just bought a new 70" TV and want a decent sytem 5.1 (even I may not use the rear as I am not going to pull wire in the famly room. (FYI we already have a home theater in the basement)
so I went and listen to a couple of system
Yamaha for $400 the sound is not great IMO
Denon DHT-1312BA
so far I feel the denon is the only decent HT I found
I also liten to the panasonic with the BR incorporated but same far from the denon
smoke90 is offline
Old 06-09-2013, 01:09 PM
smoke90's Avatar
By the way I end up spending much more money but it was really worth it
I bought a Pionner Elite VSX60 with a Definitive Procinema 600
smoke90 is offline
