How to get Xbox 360 working with 5.1 sound? Please help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-03-2012, 07:29 AM - Thread Starter
Chri5123's Avatar
Hi Guys,
I wonder if you can help me?
Firstly let me apoligize as I am a complete noob when it comes to audio/ vision and new TV's.
Here is the problem:
I am trying to get 5.1 sound on my Xbox 360.
I have this 5.1 system:
Panasonic SC-XH150EB-K 5.1 1000W Home Cinema System
My Xbox 360 is one of the old ones without a HDMI port HOWEVER in the aerial slot there is a slot for an optical audio cable.
So I have plugged in all connectors on the Xbox 360 to the TV - the TV is this one btw:
LG 42LW450U 42 Inch Full HD
Then I have plugged the left and right audio Xbox 360 leads into the 5.1 system and the optical audio cable from the Xbox 360 to the 5.1 system.
Now I CAN get sound through the speakers but the only ones that are working are the front left and right ones.
I have selected Dolby Surround 5.1 in the audio settings on the Xbox 360.
Anyone help me please?
Just a recap as I know my writing style is not very clear:
1. left and right audio adapters from the Xbox 360 go to the 5.1 system
2. optical audio cable is going from the Xbox 360 to the 5.1 system
3. front left and right speakers are the only ones working
How can i fix this?
Chris
Chri5123 is offline
post #2 of 2 Old 04-03-2012, 07:53 PM
bradymartin's Avatar
Quoted: 33 Post(s)
"Then I have plugged the left and right audio Xbox 360 leads into the 5.1 system and the optical audio cable from the Xbox 360 to the 5.1 system."
unplug the left and right audio Xbox 360 leads from both the xbox and the 5.1 speaker system (you dont need it and it wont give you dolby d or dts). leave the optical wire plugged into both. then make sure your input on the 5.1 speaker system is set to that particular optical connection.
bradymartin is offline
Reply Home Theater In A Box
