YHT 395 EQ settings - AVS Forum | Home Theater Discussions And Reviews
Old 04-16-2012, 03:38 PM - Thread Starter
mooky9669's Avatar
I have a YHT-395 and sounds great. I just wanted to know if anyone has or has used this home theater and changed the EQ settings and what settings? I haven't changed my settings and not sure of the settings to use. Thanks in adavance
mooky9669 is offline
Old 04-16-2012, 07:31 PM
Otto Pylot's Avatar
Quoted: 1373 Post(s)
Liked: 858
I've had this system for almost a year and love it. Plays very nicely with my LG, Panasonic BDT-210, and the AppleTV2. TV is OTA only and 5.1 is crisp and clear (when broadcast). DVD/BDs sound great! I'd have to go back and check it out but I'm not sure if I set any EQ settings other than what was default. Speakers are set to Small and output at 6 ohm, and the sub cross-over is 80Hz (default). Can you be a bit more specific on what you're looking for?
Otto Pylot is offline
Old 04-18-2012, 06:58 AM - Thread Starter
mooky9669's Avatar
I was just wanted to know what eq settings were for people who used it...think you told me you didn't set the EQ before..
Old 04-18-2012, 11:43 AM
Otto Pylot's Avatar
Liked: 858
experiment then sound is determined a lot by the room conditions and no two rooms are the same.
