Any In-Wall / In-Ceiling Speaker Home Theaters in a Box systems? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-09-2012, 06:24 PM - Thread Starter
AjayR's Avatar
Hi! I'm hoping you can help with an objective opinion. First off, I'm not an audiophile. Just looking for good sound for my home theater project.
I'm doing a new home theater (converting a standalone single car garage and the room will measure 14Wx16Lx11H)
I was thinking of getting a Pioneer 7.2 AV tuner to support my 3D projector (either the panasonic7000, optomaHD33, or Epson5015).
I'm struggling with finding the right speaker set-up because I'm not much of an audio guy.
I also found what looks like it is perfect, but has historically had dubious reviews - New Acoustic Audio. They have a product that you can find at thedeepdiscount dot com site and if you search for HD-728 and then click on the HD 15" sub option for $578, you'll see their speaker package. It's the only 7.2 in wall / in ceiling speaker package that I've been able to find without having to either hire a professional home theater shop or venture off into the dark corners of the audio universe to figure out how to piece together a solution.
Does anyone have any thoughts on viable solutions?
Ajay
AjayR is offline
post #2 of 2 Old 05-09-2012, 06:42 PM
pokekevin's Avatar
Liked: 102
Whats your budget? Triad makes great in wall speakers. So does Atlantic tech
pokekevin is offline
Reply Home Theater In A Box
