Polk Audio TL1600 5.1 vs Martin Logan MLT-1 5.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-26-2012, 07:43 AM - Thread Starter
viperman999's Avatar
Hi,
As space is a restiction, I'm the process of picking up a 5.1 speaker package a receiver. Budget for the 5.1 package is $300. The 2 5.1 package I can't decide on are the Polk Audio TL1600 vs Martin Logan MLT-1. Both can be had for the same price $280ish. I'm leaning more towards the ML because the sub is 100w vs 50w on the PA. The drivers are also bigger 3.5 for ML vs 2.5 PA.
Can anyone with personal experience or objective opinions suggest which to get?
Btw, I will be purchasing a Pioneer VSX-822-K $280 or VSX-1022-K $329 receiver. I think for $50 more I'll step up to the VSX-1022-K.
Thank you
viperman999 is offline
Reply Home Theater In A Box
