LG LHB336 HDMI not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-27-2012, 05:10 AM - Thread Starter
beejaycee's Avatar
I've used the component output from my LHB336 to my Optoma projector for almost a year. I switched to a newer Epson projector that has an HDMI input but I can't get the HDMI output from the LHB336 to work.
The cable is good b/c I tested it w/my satellite receiver & the projector. I even tried a different cable with no luck. I brought a small HD TV from another room hooked it up but it still does not work. I've switched resolutions with the same results. I tried putting a DVD in the player and still no HDMI output.
Any suggestions are appreciated!
beejaycee is offline
post #2 of 5 Old 05-27-2012, 07:44 AM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Hi beejaycee, don't take this as disrespect, but double check the connections on the LHB336 (HDMI In and HDMI Out).
Another suggestion: power everything down, unplug power cords, reconnect HDMI cables and plug in power cords. First turn on projector then LHB336 and last the source (giving a few seconds in between turn on).
JChin is offline
post #3 of 5 Old 05-27-2012, 08:25 AM - Thread Starter
beejaycee's Avatar
Thanks for the help! Done, done, and done. Still no HDMI. I even took it to a different room to test on another HDTV with another cable. I tried different resolutions and the auto setting. Nothing.
post #4 of 5 Old 05-27-2012, 09:34 AM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Since you haven't mention it, try resetting LHB336 back to factory default.
JChin is offline
post #5 of 5 Old 05-27-2012, 06:21 PM - Thread Starter
beejaycee's Avatar
Thanks. I realized that I had 2 days in the warranty and it's being shipped back to LG.
Reply Home Theater In A Box
