Assistance in Setting Up Home Theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-09-2012, 06:34 AM - Thread Starter
troyst's Avatar
I recently purchased a 46" 3d TV with a 3d Blu-ray player. I had been wanting to upgrade my TV for a few months, and I found a great deal off a brand new Sony (over 60% off). I would like to setup my entire system to have surround sound and good picture. Below, I've listed my toys with links to the product if possible. (I'm not going to list all of the composite/component/old audio/video connections) Can anyone help in giving me advice in how to connect all of my devices correctly?
Television
Sony 46" LED HX820 Internet TV
Inputs/Outputs: 1 Digital Audio Output, 4 HDMI Connections
Cable Box
Inputs/Outputs: 1 Optical Audio Output, 2 HDMI Connections
Sony Home Theater System (Contains internal DVD Player)
Sony DAV-DZ170
Inputs/Outputs: 1 Optical Audio Input, 1 Coaxial Input, 1 HDMI Output
3D Blu-ray Dis Player
Sony BDP-S580
Inputs/Outputs: 1 Digital Audio Output, 1 HDMI Output
That should cover it. Now, how do I get all of my devices to play through the sony home theater surround sound?
Appreciate the help!
-troyst
troyst is offline
post #2 of 2 Old 06-09-2012, 07:58 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Just follow the instructions for each component. If a source has HDMI out, then connect it to the HDMI in on the receiver.
You only have two sources, BD and cable box. If needed, also connect the digital audio either coax or optical.
Using HDMI, means you only have one wire going to the TV.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
Reply Home Theater In A Box
