Please Help - Need Small Audio/Video Receiver (hopefully with Built in DVD Player) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-15-2012, 07:46 AM - Thread Starter
casakid06's Avatar
This is for my master bedroom. I want to get some speakers hooked up as the sound coming from my TV isnt stellar. I have a cable box, appletv, and a dvd player (all use HDMI). I am looking for a small a/v receiver so i can hook up all the components and have speakers to provide better sound. It would be even better if the unit had a built in dvd player, but that isnt necessary. I found harmon kardon has one (http://www.harmankardon.com/EN-US/Products/Pages/ProductDetails.aspx?PID=BDS%20370/120) but I don't want to spend $900 on it.
Anyone have any suggestions?
casakid06 is offline
post #2 of 2 Old 06-15-2012, 08:18 AM
Otto Pylot's Avatar
Quoted: 1627 Post(s)
Liked: 1023
You might want to look at Yamaha, Onkyo, Denon. I believe they make HTiBs systems with and without built-in DVD players for considerably less than $900 ($300 - $500). They will be 5.1 systems but you don't have to use all of the speakers. Or, you could go with separates (DVD player, receiver, and a pair of front speakers). You'll get more equipment with a HTiB but you'll get better performance out of separates.
Otto Pylot is offline
Reply Home Theater In A Box
