Yamaha YHT-397BL or Denon DHT-591BA? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-14-2012, 03:51 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
Which one is better? I was going to get denon refurb but it sold out...so thinking of getting yamaha as a good alternative?
what you think?
here are differences..
yamaha new: $399 w/ 2 year warranty
600 watt system
ypao
yamaha speakers (82-85dB sensivity)
higher Frequency Range/Response
denon refurb: $367 w/ 1 year warranty
475 system
audyseeys
BA speakers (88dB sensivity)
lower Frequency Range/Response
anything else i'm missing?
EDIT: The Bold parts are what I updated
5.1 small-room size: 800 ft³+ 54 ft³ corner door space
AVR: Denon 1712
Fronts: Pioneer SP-BS41-LR /Center: Pioneer SP-C21 / Rear: Pioneer SP-BS21-LR
Subwoofer: SVS PC12-NSD
Screen: Samsung UN46EH6070 46" 1080p 3D LED 240 CMR TV
Viewing distance: 7.33 ft
Stealth3si is offline
post #2 of 4 Old 08-14-2012, 05:59 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
I have the Yamaha 395 and have been quite happy with it. The speakers are ok for our size room but definitely an upgrade should be considered down the road. We've had it for over a year now and it has played extremely well with the other components. YPAO calibration is a bit more cumbersome but you can achieve very good results with it. Audyssey is more automated and is supposed to give you better results but personally I'm not all that convinced. If you are a real audiophile it might be the way to go but it all depends on room furnishings, if you always sit dead center, etc. Denon makes good system and BA speakers are fine as well. You might want to look at the sensitivity of the speakers for comparison. My Yamaha's aren't as sensitive as I'd like (Yamaha isn't known for their speakers) so that's why I'm looking around, but blu-rays with lossless audio sound really good with what I have now.
Otto Pylot is online now
post #3 of 4 Old 08-14-2012, 09:22 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
what's your size room? mine is 10x10 and i sit nearer to the rear center of the room.
as for speaker comparisons i went ahead and updated YHT-397 and DHT-591BA on the original post....seems Denon is better
i took the liberty to further compared 397 vs 395 speakers/subwoofers and they are identical, except 397's SW model is YST-SW012BL2 instead of YST-SW012BL. Not sure what the differences are but the Yahamh websites seems to show identital specs.
As for the receiver features they are different.
$329.99 - YHT-395:
1 Dock port (for optional YDS-12 or YBA-10)
Front Analog Audio Input
$399.99 - YHT-397:
USB Input for iPod/iPhone, USB Memory, Portable Audio Player
Front USB Input
YPAO
4K Pass-through
Color OSD
ECO Mode
Two main concerns I have if I decide between 395 and 397:
1. Does 395 have a speaker configuration thingy like YPAO / Audyssey EQ2 or something of that effect?
2. What's the main benefit of 4K pass-through and what does it mean for the consumer?
AVR: Denon 1712
post #4 of 4 Old 08-14-2012, 10:33 PM
Otto Pylot's Avatar
Liked: 852
My room is about 17x20, with an 8' cathedral ceiling. Big sliding glass door on the left side of the HTS (curtain covering), carpeted floor, and leather furniture. Fronts are at least 6' apart and the sides are even with the back of the couch (which is against the wall). Speakers are set to small and the crossover is set at 80Hz. Subwoofer volume is set at about mid-point. YPAO calibrated. We don't listen to window-shattering volumes so that may be a consideration if you do. Seating is whatever is comfortable for whoever is there ( I usually sit dead center when watching tv/movies but not always). I'm not sure about 4k passthru but it sounds like a spec that is available once 4k is offered (if ever). It seem that a lot of mfrs will claim specs that aren't yet consumer-ready, at least that's my read. I don't worry about those specs. The Yamaha matches well with my LG LD520, Panasonic BDT-210 BD player, and the AppleTV2. TV is calibrated so I don't use any of the artificial video processing available on the Yamaha and the Panasonic. I also don't use any of the artificial audio processing that is available on the Yamaha (which is actually the RX-V371 receiver) AVR. I play the audio as recorded, whether it be BD, DVD, or OTA tv.
Reply Home Theater In A Box
Yamaha , Yamaha Yht 397 5 1 Channel Home Theater System , Denon Avr 591 Receiver , Receivers Amplifiers
