Sony 3D Bluray Home Theater Model BDV-E390 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-14-2012, 10:04 PM - Thread Starter
troyhash's Avatar
Thinking about purchasing the BDV-E390 system, does anyone have any information on it? Reviews, etc.? Thanks, Troy
troyhash is offline
post #2 of 6 Old 10-12-2012, 04:31 PM
Sony Junkie's Avatar
Sony's BDV-E390 Home Theater in a Box is running OK for me.
This is my first AC3 / 5.1 decoder & amp.
EZ to buy, set-up, & play.
Mine came from Sears & the Firmware Update was needed..
avsandrew likes this.
Sony Junkie is offline
post #3 of 6 Old 01-24-2013, 12:06 PM
dreamfield42's Avatar
I have the Sony BDV-E385 which, I believe, is the same unit minus the ipod dock. I think this is a great unit. I have it connected to a Sony KDL-52v5100 52" TV in a 12' X 14' room. The speakers produce great sound. It is very easy to connect, but I as disappointed that it came with no hdmi inputs. I have since read that that is pretty typical for a HTIB. I had to improvise on my hook up as I was prepared to only use hdmi. Otherwise, I have no complaints. The NetFlix and other apps are easy to set up and use.
dreamfield42 is offline
post #4 of 6 Old 01-24-2013, 02:10 PM
Otto Pylot's Avatar
Quoted: 1357 Post(s)
Liked: 852
No, that is not typical for HTiB systems. Maybe, if you get one with a built-in blu-ray player (which means the system probably has a passive sub-woofer which doesn't produce the deep, clear bass that an active sub would) and speakers with proprietary connectors. Most entry level and above HTiB systems from Yamaha, Onkyo, Denon, etc that don't have integrated blu-ray players have all the inputs you'd need.
Otto Pylot is online now
post #5 of 6 Old 05-27-2013, 10:44 AM
steves40th's Avatar
Can you play BD-RE discs?
I also use optical audio input from Cable box.
steves40th is offline
post #6 of 6 Old 08-11-2013, 10:46 AM
avsandrew's Avatar
i need a review for this bluray 3d bdv-e385 home theater system and is letter box better than pan scan and i have a philips 47" hdtv 120hz 1080p
avsandrew is offline
Reply Home Theater In A Box
