How to connect different devices - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-20-2012, 02:50 AM - Thread Starter
JaVae's Avatar
First off, I don't know if this is the right subforum, but couldn't find anything "closer" to my needs.
Here's the situation, I have these devices:
- Logitech Z906 speaker set
- Samsung UE46ES6100 LED TV
- xbox 360
- HTPC
- "tv box" (through which we watch regular cable programming)
My question is, what's the best way to hook these things up to the speaker set?
This is the current setup:
- xbox360 HDMI to TV for video, optical to Z906 for audio
- HTPC HDMI to TV for video, optical to Z906 for audio
- TV box: component to TV for video, RCA's to Z906 for audio (due to lack op opticals left)
But this TV also has an optical OUT, so I was wondering if is was better to just hook up all 3 devices with HDMI to the TV, and use the TV's optical out to my Z906.
Would this improve or worsen any audio delays?
Because now I imagine that sending audio and video to different devices can cause some delays (sometimes 0,2 sec I've noticed), so I was wondering if the TV would be smart enough to keep things more in sync if it received both audio and video through HDMI and send the audio through it's optical out itself?
JaVae is offline
post #2 of 2 Old 08-20-2012, 06:12 AM
Selden Ball's Avatar
Quoted: 3093 Post(s)
Liked: 1510
If you connect everything to the TV, the audio should be automatically sync'd with the video, but that probably will introduce another problem:
Most U.S. TVs forward only stereo through their optical audio outputs. They provide multichannel audio only for channels received through their internal tuner. I suspect your TV has this same limitation, but you should test it.
You will get the best audio/video timing match and least gaming lag when the video sent to the TV is 1080p (so the TV doesn't have to scale it) and all of the TV's internal processing features (noise reduction, etc) are disabled.
Selden
Selden Ball is offline
Reply Home Theater In A Box
Selected Z906 5 1 Surround Sound Spkrs By Logitech Inc , Speaker Systems , Samsung 46 Led Smart Tv , Xbox 360 250gb Console With Kinect
