$700 HTIB or Build my own? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-04-2012, 12:26 PM - Thread Starter
fatpirate's Avatar
I am trying to decide whether or not to buy a HTIB. I have no experience building my own system but I see that most people recommend building your own. Can I put together a better setup on my own for $700 and what would you suggest? I am getting a projector and my room size is 15' x 20'.
fatpirate is offline
post #2 of 7 Old 09-04-2012, 06:12 PM
Nick_si's Avatar
http://www.accessories4less.com/make-a-store/item/BOSA360WHA/BOSTON-ACOUSTICS-A360-3-Way-Dual-6.5in-Tower-Speaker-Each-White/1.html two of those,
one of these http://www.accessories4less.com/make-a-store/item/BOSA225CWHA/BOSTON-ACOUSTICS-A225C-2-Way-Center-Channel-Speaker-White/1.html
and a pair of thesehttp://www.accessories4less.com/make-a-store/item/BOSSWXSSEW/BOSTON-ACOUSTICS-SoundWare-XS-Special-Edition-Speaker-Each-White/1.html and one of thesehttp://www.accessories4less.com/make-a-store/item/ONKHTR580/Onkyo-HT-R580-7.1-Channel-3-D-Ready-Home-Theater-Surround-Receiver-From-HT-S5300-Package/1.html#!more
Now if you were keeping track that is 760 so I did go a bit over... But It will be worth those 60 because those speakers will last for years and years and they will let you get by without a sub for a little while until you can save up a little bit $100 will do it for a dayton or a BIC.
Thats what i would do... or you could buy one of the many recommended systems here in other threads. Energy Take classics etc
Nick_si is offline
post #3 of 7 Old 09-08-2012, 05:16 PM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 972
For $700 you can put together a better system yourself. This is assuming you're in the USA.
Pioneer FS51 towers, $140/pr
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117403
Pioneer C21 center, $60
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117404
PIoneer BS-21 surrounds, $50 after using promo code EMCNANF72
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405
That's only $250 which leaves you plenty for a receiver and subwoofer.
If you buy this Yamaha 373 receiver you get a free pair of Pioneer BS-21 speakers which will save you $50.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882115373
That means you'll have only spent $450 so far leaving you $250 for a subwoofer.
Energy s10.3 $229
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026
Kllpsch RW!2d, $299 if you don't mind going over budget by $50.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
eyeguy1 likes this.
Afro GT
afrogt is offline
post #4 of 7 Old 09-08-2012, 06:25 PM
Ifinallygota21v's Avatar
How would these setup work in a living room?
Ifinallygota21v is offline
post #5 of 7 Old 09-08-2012, 06:43 PM - Thread Starter
fatpirate's Avatar
Frogt that suggestion looks spot on. between the subs the klipsh seems to have much better reviews and I like that option. This will be my first surround system and it will be connected to a projector. do you have suggestions for speaker cable? what other accessories might I need? Also is Newegg a good source for speakers and audio? I have built my last three computers out of components I bought there and have been satisfied.
post #6 of 7 Old 09-08-2012, 07:03 PM
afrogt's Avatar
Liked: 972
Newegg is a good source for those Pioneer speakers, some Definitely technology bookshelf speakers, Polk Monitor speakers and a few subs. they don't have a huge selection of audio stuff.
If you need cables, speaker wire, etc go to monoprice.com. you can't beat their prices. Great quality for cheap.
www.monoprice.com
Afro GT
afrogt is offline
post #7 of 7 Old 01-08-2013, 05:27 PM
eyeguy1's Avatar
Bump for the Frog -
been building speakers since, omg, more than 30 years.
if your time is worth nothing and you have a great wood shop -
you still can't build a HTIB for $700
I picked up the sp-21c from the egg on sale for little, and they are worth it.
search for Andrew Jones KEF
if you are talking thousands - then build some Seas Thors and Odins-
otherwise buy some good deals
eyeguy1 is offline
Reply Home Theater In A Box
Bose , Pioneer Sp Fs51 Lr Floorstanding Loudspeakers Black Pair , Pioneer Sp C21 130 Watt Rms 2 Way Speaker , Pioneer Sp Bs21 Lr 80 Watt Rms 2 Way Speaker , Subwoofers , Klipsch , Klipsch Rw 12d 12 Subwoofer Each
