BEGINNER HERE, NEED SOME HELP AND ADVICES. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-21-2012, 06:56 AM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
hello sir's. i need ur help and advices which receiver i need to get for my 5.1 surround sound. as of the moment this is the model i have Philips HTS3372D/F7. is it possible if i can get a 5.1 receiver by using those speakers and subwoofer? any help and advices, suggestions is appreciated. thank you so much.
caloyzki is offline
post #2 of 9 Old 09-21-2012, 09:22 AM
Otto Pylot's Avatar
Quoted: 1369 Post(s)
Liked: 857
What kind of connectors do the speaker wires have? If they are non-proprietary (bare wire for example) then just about any kind of receiver would work as long as the ohm rating is matched. You don't want 4 ohm speakers powered by an 8 ohm only receiver.
Otto Pylot is online now
post #3 of 9 Old 09-21-2012, 06:24 PM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
According to the specs they are 4 ohm speakers. They only have a single 3" driver and the subwoofer is passive so you'd be better off getting something else anyways.
http://www.usa.philips.com/c/home-theater-systems/hts3372d_f7/prd/en/;jsessionid=603E0C77381BFA14035593EE977A451D.app102-drp1?t=specifications
Loudspeakers
Satellite speaker drivers: 3" full range woofer
Satellite speaker impedance: 4 ohm
Satellite speaker freq range: 150-20000 Hz
Center speaker drivers: 3" full range woofer
Center speaker impedance: 4 ohm
Center freq range: 150-20000 Hz
Subwoofer driver: 6.5" high efficiency woofer
Subwoofer impedance: 4 ohm
Subwoofer freq range: 40-150 Hz
Subwoofer type: Passive
Afro GT
afrogt is offline
post #4 of 9 Old 09-22-2012, 07:53 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
thanks for the reply guys. can u guys give me a good set up. i really dont care about any new advance receivers or anything like that, all i only need is a descent surround sound of course better what what im using now.lol.
i only use it for my 55" HDTV 3D, PS3 gaming and watching bluray movies and lastly for my cable box DTV DVR. my only budget is $600 for both descent receiver and speakers. i only live in apartment so same size of speakers what i have now is my preferable sizes or a lil bigger is ok. any recommendations guys? thanks.
caloyzki is offline
post #5 of 9 Old 09-22-2012, 08:47 PM
Nick_si's Avatar
You need a denon 1612, it has hdmi and room correction. For speakers get the jamo s 426 and a sub from parts express the small Dayton the 100$ one. That put you to $500. Should be a grat sounding system
Nick_si is offline
post #6 of 9 Old 09-23-2012, 07:11 AM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
is this a goo set up sir? this is im planning to buy for my speakers http://www.woot.com/offers/energy-take-classic-5pc-speaker-system and this is the receiver which is i dont know if it is good combo with my speakers and tvs ps3 and cable box http://www.amazon.com/Denon-AVR-1612-Channel-Theater-Receiver/dp/B004U403WM/ref=sr_1_1?s=electronics&ie=UTF8&qid=1348405849&sr=1-1&keywords=denon+1612
and i am still looking for a descent sud woofer. whaat do you think sir?
how about his sub is this better than energy sub? or can i use this on my set? http://www.amazon.com/Polk-Audio-10-Inch-Monitor-Subwoofer/dp/B0002KVQBA/ref=sr_1_1?ie=UTF8&qid=1348409335&sr=8-1&keywords=POLK+AUDIO+PSW+10+SUB
caloyzki is offline
post #7 of 9 Old 09-23-2012, 06:56 PM
Nick_si's Avatar
yea that would be good but the Jamo will be better than the Take Classics. You can save some money and get a refurb Denon 1612 from AC4less for about a hundred less.
Nick_si is offline
post #8 of 9 Old 09-23-2012, 08:47 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Can u pls give me link for jamo? I only have sMall apt. So big speakes not that good for my living room.
caloyzki is offline
post #9 of 9 Old 09-24-2012, 04:40 AM
Nick_si's Avatar
[=http://www.amazon.com/Jamo-S426HCS3-Theater-Speaker-System/dp/B004AIKL9I][/]. I have a tiny apt as well so I can understand the difficulty fitting big speakers lo
Nick_si is offline
Reply Home Theater In A Box
