Sony HTIB going into "Protect" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-09-2012, 04:50 AM - Thread Starter
Trevor78's Avatar
Quoted: 14 Post(s)
Hi everyone,
I have a (relatively) older Sony HTIB, model STR-K502P that is going into "protect" mode. I've re-checked all the wiring and left the box unplugged for a couple hours. This has not solved the problem yet.
Any ideas?
Trevor78 is offline
post #2 of 3 Old 10-11-2012, 01:09 AM
MandM's Avatar
Quoted: 82 Post(s)
Liked: 40
Unplug everything connected to your Sony. Does it still go into protect mode?
MandM is offline
post #3 of 3 Old 10-12-2012, 07:54 AM
SonyListens's Avatar
Originally Posted by Trevor78 View Post
Hi everyone,
Any ideas?
Good morning!
This is Kevin Krause from Sony Support USA. I am sorry to read about the problems that you are having with your receiver. The following is a link from Sony's esupport site that explains how to get your receiver out of protect mode. http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C215444&fes=true&mdl=STRK502P. If this link does not help fix the problems that you are having then please call Sony's home audio support line at 239-768-7547.
Thank you,
Kevin Krause
Sony Support USA
For helpful videos that will help answer some questions you may have about your Sony products please visit the Sony Support USA YouTube page at http://www.youtube.com/sonylistens.
SonyListens is offline
Reply Home Theater In A Box
