BH9520TW Audio/Video Syncing Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-23-2012, 12:48 AM - Thread Starter
alexchainey's Avatar
Hey guys,
First post here..! My setup is an LG 55lm9600 with a LG BH9520TW Home Theater system.. The problem I am having is to do with the Bluray player itself. Whenever watching 3D Blurays the video lags by around a quarter of a second which I have to correct in the setup every time by selecting the certain delay in the audio I wish.. Thing is though when I watch normal 2D movies or convert the 3D back into 2D the audio sync is fine... Kind of annoying seeing as I have to change the delay from 250 milliseconds back to 0 depending on what I'm watching 3D/2D... Anybody have any ideas on the problem I am experiencing? I have all the latest software on my units and am using a good quality HDMI 1.4 cable.. I have tried different HDMI cables and it is also worth mentioning I didn't have this problem on an older model LG bluray player I had..
Alex
alexchainey is offline
post #2 of 6 Old 10-23-2012, 05:55 AM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
The TV is taking that much longer to process the 3D video signal than it does to process a 2D video signal. It needs to tell the HTIB to delay the audio. Check to see if Auto Lip Sync is available and enabled in both the TV and the HTIB. (I don't have their manuals, so I can't help with the details.)
As a work-around try turning off all of the other video processing in the TV -- image sharpening and noise reduction should be disabled or set to 0, for example. Some TVs have a "game mode" which does this.
Selden
Selden Ball is offline
post #3 of 6 Old 10-23-2012, 01:59 PM - Thread Starter
Thanks mate ill give this a go, I already had AV Sync turned on on the tv which hasn't had an effect unfortunately..
post #4 of 6 Old 10-23-2012, 03:18 PM - Thread Starter
It seems that 'game mode' actually fixes the audio sync problem, obviously the picture quality is seriously degraded though... Surely I shouldn't be having this problem with both LG's latest model products and software installed, surely...?
post #5 of 6 Old 10-23-2012, 04:07 PM
Liked: 1494
HTIB boxes usually are intentionally simplified in order to keep the cost down. I did manage to download the HTIB's manual and couldn't find any mention of an auto lip sync feature, only fixed sync delays. You might want to consider getting an audio/video receiver which includes that feature. It'll probably be significantly more expensive, though, because of the other features it includes, too. Sorry, I don't know enough about the features in the less expensive AVR models to be able to make a recommendation.
Selden
post #6 of 6 Old 10-23-2012, 04:13 PM - Thread Starter
Thanks for the help mate, perhaps I will just use the delay function when watching 3D content and hope that the issue is fixed later down the track with further software updates. I have contacted LG and the only advice they gave me apart from trying a different HDMI cable was to turn on AV Sync on the TV which I already had switched on.
Alex
Reply Home Theater In A Box
