Onkyo S9100THX HTIB Volume Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-04-2012, 06:26 PM - Thread Starter
jimmykoss's Avatar
For some reason, my receive volume just recently began maxing out at +5 maximum. I have completed the auto calibration six times with the same result. My maximum volume was previously +18 maximum per max volume indicated within the manual. I have gone through all of the troubleshooting steps as well. My volume is now a bit more than half as loud as it previously was for 2 years. I used to not even be able to set it at zero without the system being too loud. I can turn it up all of the way to +5 now and it is around half of as loud as it used to be at zero. Does anyone have any feedback? Thanks!
jimmykoss is offline
Reply Home Theater In A Box
Onkyo Ht S9100thx 7 1 Channel Receiver And Speaker Package
