hi need a little help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-18-2012, 01:19 PM - Thread Starter
Chris Bailey's Avatar
hi im trying to turn my spare bedroom in to a litte cinema room but its not very big . its about ( L ) 12 ft ( W ) 8 ft and ( H ) 8 ft . i got the lg 42 550t tv for it and not sure if i can use a 5.1 home cinema systerm for the size of the room or what ones i should be looking at floor standing or the small ones . the tv and that is goin to be wall mounted . any help would be great as been doing reseach for a few hours and could not find much help with it . many thanks
Chris Bailey is offline
post #2 of 3 Old 11-18-2012, 03:19 PM
afrogt's Avatar
Quoted: 1066 Post(s)
Liked: 773
1. how much are you willing to spend?
2. What is your zip code.
3. What devices will you be connecting?
Afro GT
afrogt is offline
post #3 of 3 Old 11-18-2012, 03:58 PM - Thread Starter
im in the uk so no zip code but im look at about 300 - 400 pounds and got ps3 and sky hd box but was goin to use arc to do the sound i think
Reply Home Theater In A Box
