Newbie - Help in deciding the right combination of receiver + HT speakers ~$500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-19-2012, 08:24 AM - Thread Starter
imishelo's Avatar
Hello Experts,
I am planning to buy a HT (out-of-box) for my apartment (Size: 12 x 18) and i have a restricted size limits (small) of speakers under $500 budget
I have purchased Pioneer VSX822 for $199. Now i want to get speakers which would be best match for this. I've shortlisted below in no-order of choice as per reviews and discussion on this forum
  1. MartinLogan MLT-2 Home Theater System (Black)
  2. Polk Audio RM705 5.1 Home Theater System (Set of Six, Black)
  3. Energy 5.1 Take Classic Home Theater System
  4. Klipsch HD Theater 1000 5.1-channel Home Theater Speaker System (600/500 series are $599 currently)
i understand these are much better speakers but i need to stretch my budget on this
Definitive Technology ProCinema 600 5.1 Speaker System (Set of Six, Black)
Expert advice is much appreciated
imishelo is offline
post #2 of 5 Old 11-20-2012, 09:05 PM - Thread Starter
imishelo's Avatar
After much research and deeping my pocket i have shortlisted Definitive Technology Pro Cinema 600 or 800 series. Can i have a good recommendation on below:
1. Good matching receiver, i have Pioneer VSX 822K ( i know this wont give me the best result what speakers are too for 800 series)
2. What AWG size, any good company/brand? I keep hearing "Monster"
3. Any recommended banana plugs?
imishelo is offline
post #3 of 5 Old 11-20-2012, 10:19 PM
afrogt's Avatar
Quoted: 1435 Post(s)
Liked: 982
Can you get the Pro Cinema 800 with the $300 you have left? If so you should do it!
1. Since you already have the vSX-822 just keep it. It'll be fine for a satellite speaker setup.
2. 14ga or 16ga speakers wire is just fine. Monoprice has some of the best pricing
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023903&p_id=2793&seq=1&format=2
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023902&p_id=2791&seq=1&format=2
3. They also sell banana plugs.
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2801&seq=1&format=2
4. You'll also need a subwoofer cable
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2682&seq=1&format=2
5. maybe HDMI cables too.
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10240&cs_id=1024008
Afro GT
afrogt is online now
post #4 of 5 Old 11-21-2012, 07:48 AM - Thread Starter
imishelo's Avatar
Thank you afrogt for your suggestions and all necessary links!
I am definitely leaning more towards Pro 800 series but currently in a dilemma:
Option 1: Go with this package at BestBuy http://www.bestbuy.com/site/olspage.jsp?skuId=9999192500050004&type=product&id=pcmprd192000050004 (Includes Pro Cinema 600 and Denon AVR2113CI). I heard denon has awesome Audessy******
Option 2: Stick with my Pioneer VSX-822K and get Pro 800
imishelo is offline
post #5 of 5 Old 11-27-2012, 12:40 PM - Thread Starter
imishelo's Avatar
Finally opted for these system within my budget and room size:
Any suggestions/recommendation? I wanted to get accessories from monoprice, but shipping killed my budget
I'm still accumulating my budget to go for Pro Cinema 800 in future...
imishelo is offline
Reply Home Theater In A Box
