Pioneer HTP 071 Displaying 'Temp' then turning the volume down - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-26-2012, 12:57 PM - Thread Starter
Owen Brett's Avatar
As the title says really!
Just purchased an ex display pioneer htp 071 5.1 system and the reciever/amp keeps coming up with 'temp' on the display then turning the volume down by about 5.
I have the volume set at about 45 which is a good, not overly loud volume and it hold that for about 5 mins then turns it down.
Any ideas if its a setting I can change or a faulty unit?
Owen Brett is offline
post #2 of 6 Old 11-26-2012, 01:29 PM
Otto Pylot's Avatar
Quoted: 1361 Post(s)
Liked: 854
Is there a maximum volume configuration setting on the receiver? I know mine has a max volume but you can set the receiver to any dB reading below that in increments of 0.5 dB so that if someone accidentally turns the volume up too high it will only go the setting you have configured to protect the speakers (and possibly your ears).
Otto Pylot is online now
post #3 of 6 Old 11-26-2012, 02:06 PM - Thread Starter
Owen Brett's Avatar
Hi,
Thanks for the reply.
I can't see any mention of a max volume limit setting. I think theres a dodgy sensor in it because it drops the volume every 5ish minutes and comes up with 'temp' which, after re-reading the manual indicates the temp inside has got too high, which doesn't seem right as the unit has is not covered at all.
post #4 of 6 Old 11-26-2012, 04:17 PM
Otto Pylot's Avatar
Liked: 854
Hi,
If the Temp reading (I was hoping that stood for "temporary") actually is a temp sensor then it's doing what it's supposed to do. Turn down the volume so it won't heat up any higher than it already has. Sounds like a failing component (either the sensor or something else that is actually heating above spec and triggering the sensor). Sounds like you either need to fix it or replace it.
tucedan likes this.
post #5 of 6 Old 08-07-2013, 07:01 AM
fox1980rew's Avatar
hi,i have the same problem , how you fix it.Sorry for the bad english
fox1980rew is offline
post #6 of 6 Old 08-07-2013, 09:52 AM
Otto Pylot's Avatar
Liked: 854
You'd probably have to call Pioneer support for that unless you are good at reading specs and performing electronic repairs yourself.
Reply Home Theater In A Box
