how to get TV audio to home theater using HDMI cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-28-2012, 09:43 AM - Thread Starter
rajanis's Avatar
Hello,
My tv has HDMI in port and don't have 3.5 mm jack. Home theaters has hdmi in and hdmi out ports. I want my tv channels audio out comes through home theaters using hdmi converter cable.
Is it possible to my TV channel audio output comes through home theater ?
Best & Regards,
Rajani
rajanis is offline
post #2 of 10 Old 11-28-2012, 09:50 AM
tre74's Avatar
Look on the back of your TV for an optical output. There should be at least one optical input on your receiver(home theater). I'm guessing the TV and receiver do not have ARC.
tre74 is offline
post #3 of 10 Old 11-28-2012, 09:59 AM
flickhtguru's Avatar
Liked: 110
Originally Posted by rajanis View Post
Hello,
Best & Regards,
Rajani
Are you using a set top box for HD Cable or Satelite??? If yes, then run an HDMI from the HD box into the receiver and then an HDMI from the receiver into the TV.
Shawn
flickhtguru is offline
post #4 of 10 Old 11-28-2012, 10:11 AM
Otto Pylot's Avatar
Quoted: 1363 Post(s)
Liked: 854
...or, you can connect your cable box to the Cable/OTA input of your tv using a coax cable. That way, your tv's ATSC tuner (I'm assuming it has one) is used and you can output 5.1 audio (if the programming has it) to the receiver using an optical cable (turning off the tv's speakers first). You just need to make sure that you select the correct input on the receiver (optical/tv).
Otto Pylot is online now
post #5 of 10 Old 11-28-2012, 10:32 AM - Thread Starter
rajanis's Avatar
Hello,
Best & Regards,
Rajani
yes mt tv and home theater don't have ARC...
rajanis is offline
post #6 of 10 Old 11-28-2012, 10:36 AM - Thread Starter
rajanis's Avatar
Thank you for information... I am using HD cable... I need TV channel audio output ( ex : cricket match audio) comes through home theaters speakers....
rajanis is offline
post #7 of 10 Old 11-28-2012, 09:09 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 756
Does that mean you have a cable box or not? And what model TV do you have, I would think all of them have a optical output by now.
Afro GT
afrogt is online now
post #8 of 10 Old 11-29-2012, 04:53 AM - Thread Starter
rajanis's Avatar
I don't have cable box. i am using local cable channel. My TV model is Toshiba Regza 32HV10 LCD TV (this is basic model, no USB option also and one HDMI in port ).
rajanis is offline
post #9 of 10 Old 12-05-2012, 12:11 AM - Thread Starter
rajanis's Avatar
rajanis is offline
post #10 of 10 Old 12-05-2012, 09:19 AM
afrogt's Avatar
Liked: 756
According to the manual your TV doesn't have a an optical out or stereo outputs at all.
http://www.regza-asia.com/pdf/HV10/19-24-32HV10Series-OM.PDF
Single HDMI input
component input with stereo audio jacks
composite input with stereo audio jacks
no audio outputs at all.
this must be an older LCD tv?
since you don't have a cable box or anything I don't see a way to connect the TV to your receiver.
Afro GT
Reply Home Theater In A Box
