Onkyo HT-S5400 7.1 Speaker Mount Question - AVS Forum | Home Theater Discussions And Reviews
Old 11-29-2012, 06:06 AM - Thread Starter
joshgfeller's Avatar
Hello,
I am new to the Home Theater industry besides the old walmart special with a dvd player speaker combo and am looking at the Onkyo HT-S5400 7.1 combo to get started. My plan is to wall mount all of the speakers but have heard some complaints about getting their speakers to work with wall mounts. So my question is to those with experience with Onkyo speakers, which of these wall mounts (if any) would work with the Onkyo Speakers?
http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10828#1082804
I may still sit the front two on stands (stands are expensive) But I definitely wanted to wall mount the back ones. I plan to use wire channel molding run from the baseboard up to the wall mounted speakers, no it's not hiding the wires in the wall but it sure will look better than wires running directly across walls and floor which is what I'm used to now smile.gif
Thanks for any insight.
joshgfeller is offline
Onkyo Ht S5400 7 1 Channel Home Theater System
