Onkyo HT-R 380 Is it possible to use HDMI and toslink at the same time? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-01-2012, 10:39 AM - Thread Starter
jinx5's Avatar
Quoted: 30 Post(s)
I hooked up PC to the receiver via hdmi and want to also use toslink since my sound card is better then the video card sound.
I have it connected to game witch is labeled game and also have the toslink in the game connection but only the sound from the hdmi is going thru.
jinx5 is offline
post #2 of 12 Old 12-01-2012, 11:05 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Does the receiver have assignable inputs? Some can separately choose for video and audio source. My HTRC370 can....
lovinthehd is offline
post #3 of 12 Old 12-01-2012, 11:26 AM - Thread Starter
jinx5's Avatar
Quoted: 30 Post(s)
In the menu under digatal audio opt 1 and 2 is that it. OPT 2 is the toslink?
jinx5 is offline
post #4 of 12 Old 12-01-2012, 11:30 AM
lovinthehd's Avatar
Liked: 4775
Whichever one you have plugged it to...they're both optical inputs (toslink is just a name for an optical cable, originally from Toshiba Link)
post #5 of 12 Old 12-01-2012, 12:08 PM - Thread Starter
jinx5's Avatar
Quoted: 30 Post(s)
I have HDMI and optical (toslink) plugged in at the same time. I am trying to get audio from the optical(toslink)
Using a PC with nvidea video card for hdmi and a ht omega clario halo for optical (toslink). Went to manage audio settings in the control panel and selected S/PDIF Pass-throu for my sound card and also tried just the speakers one but my receiver still says hdmi on it. But the nvidea sound one works fine.
Maybe it's not possible to do both at the same time?
Before i was using VGA strait to the TV and toslink to the receiver and it worked just fine.
jinx5 is offline
post #6 of 12 Old 12-01-2012, 01:03 PM - Thread Starter
jinx5's Avatar
Quoted: 30 Post(s)
it works now. so happy
jinx5 is offline
post #7 of 12 Old 12-01-2012, 02:33 PM - Thread Starter
jinx5's Avatar
Quoted: 30 Post(s)
arg now when i play a game it stops working. I need to turn my receaver on and off to get it working again.
jinx5 is offline
post #8 of 12 Old 12-03-2012, 03:35 PM - Thread Starter
jinx5's Avatar
Quoted: 30 Post(s)
Well i got it working but after I select the hdmi I also have to select opt 2 TV/CD. If I do it with my remote lets me use both at the same time. It's kind of a pain but it works i guess.
jinx5 is offline
post #9 of 12 Old 12-03-2012, 08:19 PM
lovinthehd's Avatar
Liked: 4775
Sometimes the hdmi thing works best by turning on the display first then working your way back through the chain to the source. A Harmony and other programmable universal remotes can be programmed with special instructions and/or delays to compensate as well....
post #10 of 12 Old 12-04-2012, 01:35 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If you are sending digital signals why do you feel one soundcard is better than the other?
Afro GT
afrogt is offline
post #11 of 12 Old 12-06-2012, 02:03 PM - Thread Starter
jinx5's Avatar
Quoted: 30 Post(s)
Because it's a HT Omega Clario Halo and it is better then the onboard video card sound.
jinx5 is offline
post #12 of 12 Old 12-07-2012, 05:28 PM
Jads's Avatar
Can you just skip the receiver for video and plug your PC directly into your TV / monitor?
Then your toslink would be audio only to your receiver and you could select which sound device was supplying your audio, hdmi or toslink.
Jads is offline
Reply Home Theater In A Box
