Yamaha rx-v473 and android tablet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-04-2012, 04:16 AM - Thread Starter
crazygravy's Avatar
Have an Asus tf201 prime tablet. There isan app I have installed called Wolfgang's Vault (Concert Vault). It accesses thousands of recorded live concertsfrom their web site. Anyone know of a way to get that content to the rx-v473 wirelessly?
Bob
crazygravy is offline
post #2 of 2 Old 12-06-2012, 12:50 AM
jevans64's Avatar
Quoted: 208 Post(s)
Liked: 162
You would have to have wireless capability on the Yamaha OR have both on the same network.
There are a few android apps you can try out to see if you can make the tablet part of your network.
ES File Explorer
Samba
TeamViewer
These are mainly for transferring data between tablet and a PC. Not sure if they will work for streaming data. I just simply connect my Asus TF700T directly to my receiver with the HDMI cable and pipe A/V to the receiver and to the TV.
There is an app called MyNet pre-installed on Asus tablets that lets you access and play content that is on a network-connected PC. Don't really use it much because I transfer data way more than I stream from a PC.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
Reply Home Theater In A Box
Yamaha Rx V473 Receiver
