Best bang for the buck HTIB under $600? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-07-2012, 07:19 PM - Thread Starter
ravencr's Avatar
My father-in-law wants a system to hook up to his tv and to play music, especially his old records. What's the best options out there for under $600 for the HTIB only? The turntable will be on top of the $600. Thanks in advance for the help.
ravencr is offline
post #2 of 3 Old 12-08-2012, 02:53 PM
jevans64's Avatar
Quoted: 208 Post(s)
Liked: 162
That is going to be a tough nut as most, if not all, HTiB's have given up the Phono Input. Maybe Onkyo HT-S5500 to Onkyo HT-S7409 and purchase a Phono Pre-amp. The pre-amps are generally very small and can be tucked beside or behind the receiver and are usually under $50. You can also purchase a new turntable WITH line-level RCA output. They basically have the pre-amp built into them.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #3 of 3 Old 12-08-2012, 06:13 PM - Thread Starter
ravencr's Avatar
K thanks. We're going with the 5500 onkyo.
ravencr is offline
Reply Home Theater In A Box
