Optical input on a Samsung HT-BD1250 Blu-ray 5.1 HTiB, problem is very low volume. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-30-2012, 08:28 PM - Thread Starter
Tacoboy's Avatar
I have a five day old Vizio M470SL 47" TV with it's optical output connect to the optical input on the Samsung BD-1250 5.1 HTiB (latest firmware).
When trying to feed (optical digital) audio from the TV to the Samsung, all I get from the Samsung's speakers is a very very low whisper of an audio signal.
(otherwise both TV and HTIB work fine on their own, and HDMI from HTIB to TV works great)
(Vizio TV get it's feed from a satellite dish, using coaxial cable from Dish to TV).
I've tried switching the TV's optical output feed between PCM & Dolby Digital settings
Switched TV back and forth between variable & fixed audio output (assuming fixed is the correct setting).
Check optical cable connections.
I put the Samsung on Digital optical input.
So the signal is getting thru, but it's only a whisper.
Any ideas on what else I can try to fix this problem?
Yamaha RX-V671 receiver
Infinity Beta 5.1
Vizio D58U-D3 (Costco) TV
Tacoboy is offline
post #2 of 6 Old 12-30-2012, 11:09 PM
Otto Pylot's Avatar
Quoted: 1368 Post(s)
Liked: 854
Does the Vizio play audio fine (Dish TV) thru it's speakers without being connected to the Samsung?
Otto Pylot is offline
post #3 of 6 Old 12-31-2012, 12:13 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Try a different optical cable. And try plugging in a different device such as a disc player to that input. These are steps to isolate which piece of equipment is at fault.
BIslander is offline
post #4 of 6 Old 12-31-2012, 11:59 AM - Thread Starter
Tacoboy's Avatar
The dish is directly connected to the Vizio (coaxial cable), that connection works fine (with or without the Samsung).
The Samsung is connected to the Vizio, HDMI-1, the only input used on the Samsung is the optical, from the Vizio.
Infinity Beta 5.1
Tacoboy is offline
post #5 of 6 Old 12-31-2012, 12:00 PM - Thread Starter
Tacoboy's Avatar
I guess I have a few extra optical cables lying around.
Infinity Beta 5.1
Tacoboy is offline
post #6 of 6 Old 12-31-2012, 02:41 PM
Otto Pylot's Avatar
Liked: 854
Ok. Then BIslander's suggestion for isolating the issue is the next step.
Reply Home Theater In A Box
