How do you connect the Pioneer HTP100-SW sub-woofer to the VSX-516 receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-06-2013, 01:24 PM - Thread Starter
xmas97's Avatar
I have the old Pioneer speakers from the old Pioneer VSX-305 receiver, they are still good.
I am now using the newer Pioneer VSX-516 receiver.
When I connect the passive sub-woofer (HTP100-SW) like it shows on the back of the sub-woofer (front speakers to sub-woofer and from there to front connections on receiver), the sub-woofer doesn't work, only the front speakers work.
The center speaker works as it should when connected to the center speaker connection.
But when I connect the rear speakers to the Surround speaker connections on the receiver, they do not work either.
Anyone know what I should do?
xmas97 is offline
post #2 of 5 Old 01-06-2013, 01:28 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
What speaker setup did you do in the receiver? You do need to do that...you know, RTFM smile.gif http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/297336630VSX516OperatingInstructions.pdf page 28.
PS I did the same just now, actually RTFM that is, and it is assuming when it says you have a subwoofer that you're using the sub preout with an active sub; you have a passive sub so you need to set your front L/R speakers to large as otherwise your avr has no idea you have a subwoofer connected....
lovinthehd is offline
post #3 of 5 Old 01-06-2013, 02:36 PM - Thread Starter
xmas97's Avatar
I'll try that.
What about the rear speakers, how do I get them to work too? Do I use 5.1 speaker setting or 5.0 since the sub-woofer is passive? I only have the two front, two rear, center, and sub-woofer speakers.
xmas97 is offline
post #4 of 5 Old 01-06-2013, 02:56 PM
lovinthehd's Avatar
Liked: 4775
Do the setup. You don't have a subwoofer as far as you're avr is concerned (i.e. there is no .1, i.e. the LFE channel, being used).
post #5 of 5 Old 01-06-2013, 06:22 PM - Thread Starter
xmas97's Avatar
Thank you, all the speakers seem to be working now.
xmas97 is offline
Reply Home Theater In A Box
Pioneer Htp 100sw Woofer W 70 Watts Maximum Power Handling
